![]() | Home > Technical (L405) > Possible Turbo issues |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2550 ![]() ![]() ![]() |
Only early 4.4 TDV8 had issues with a sticky CSOV prior to LR changing the linkage design. My MY12 has the later design so shouldn't be an issue on L405s. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8672 ![]() ![]() ![]() |
Tend to agree, but it’s worth a look and a fiddle, nothing to say the solenoid hasn’t given up. There is nothing that can't be fixed with a hammer😜😜
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2587 ![]() ![]() |
It does affect L405s. |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 62 ![]() ![]() ![]() |
The OP mentioned earlier in this post that it had been diagnosed at the turbo shut off valve. This is not the CSOV valve. The turbo shut off valve is on the left hand turbo , and is prone to sticking. See my post earlier in this thread. |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1746 ![]() ![]() ![]() |
Just so I’m up to speed… when we say left hand that’s ’near side’ in the UK not left hand looking at the engine from the front - is that correct?
Hi Dtech
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1257 ![]() ![]() ![]() |
Have a look at these pictures.
Thanks Kevin
Yes that’s the one I am referring to. The CSOV is in a totally different location, low down in front of the engine. |
It's at about ten o'oclock on my pictures.
Hmmm - Thanks Kevin
Reading your other post on this Kevin I thing you have just found the cause of my losing oil.
Somewhere on this forum somebody said that they had had some made. Have a look in the for sale section. |
