![]() | Home > Technical (L405) > Possible Turbo issues |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2642 ![]() ![]() |
Only early 4.4 TDV8 had issues with a sticky CSOV prior to LR changing the linkage design. My MY12 has the later design so shouldn't be an issue on L405s. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Tend to agree, but it’s worth a look and a fiddle, nothing to say the solenoid hasn’t given up. There is nothing that can't be fixed with a hammer😜😜
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2617 ![]() ![]() |
It does affect L405s. |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 69 ![]() ![]() ![]() |
The OP mentioned earlier in this post that it had been diagnosed at the turbo shut off valve. This is not the CSOV valve. The turbo shut off valve is on the left hand turbo , and is prone to sticking. See my post earlier in this thread. |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1754 ![]() ![]() ![]() |
Just so I’m up to speed… when we say left hand that’s ’near side’ in the UK not left hand looking at the engine from the front - is that correct?
There is a fair bit of oil on the base surrounding where the filter sits as well…
If you zoom in to where the filter screws in, there is some silver metal plate that goes all the way the centre metal tube - it appears to be screwed to the base top right (about 2 o’clock) and what appears to be another hole where perhaps should also be screwed down bottom left (about 8 o’clock) - is that an issue or as designed - perhaps not important. Can’t see any oil anywhere else. I took the main hose out to see if I could see anything but nothing that looks like the diagram you shared - I don’t see anything I could try to move.
So, whilst it was a fun morning, i don’t think I got any closer. ![]() ------------------------------------------------------ 2022 SDV8 AB 2016 TDV8 VSE 2011 TDV8 VSE 2006 V8 Vogue 2002 2.5 Vogue |
Hi Dtech
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1293 ![]() ![]() ![]() |
Have a look at these pictures.
This is with the valve missing.
Looks like yours is fitted. Just check the rubber bung is in place and not missing. |
Thanks Kevin
Yes that’s the one I am referring to. The CSOV is in a totally different location, low down in front of the engine. |
It's at about ten o'oclock on my pictures.
Hmmm - Thanks Kevin
Reading your other post on this Kevin I thing you have just found the cause of my losing oil.
Somewhere on this forum somebody said that they had had some made. Have a look in the for sale section. |
Members name 'Butcher' Also, make sure the plastic cage is fitted down the center of the oil filter. |
