![]() | Home > Technical (L405) > power steering fault |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 487 ![]() ![]() ![]() |
just started the rr again and as soon as you try to turn the wheel it sort of juddrs in your hand and makes some very strange noises and wont move .............dont think this is just bad earth connection (could be wrong ) feels more mechanical...thinking more pump or rack |
right just watched video by powerful uk ref a rebuild kit for the rack and the noise that they show when a bolt has snapped is exactly the noise im getting |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1656 ![]() ![]() ![]() |
Yes, this is a common fault with the L405, 3 small bolts holding up that long & heavy motor are prone to snapping off:
anybody replaced the steering rack ? and if so how much of a pain is it to do ......have had a quick look at the wsm as undecided weather to do myself or get a local indy to do it |
if i can get to the steering rack motor i may just get away with replacing the faulty bolts (fingers crossed thats all it is ) |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1450 ![]() ![]() |
I think the issue commonly is that the bolts shear in the casing ... which I dont fancy being fun to get out. V8 or else ... |
You may be very lucky, given it apparently wasn’t driven like that, but no more wheel twirling, eh?
Yes, more of a job for longer, warmer days, with lots of patience and time. “If it ain’t broke, don’t fix it” -where’s the fun in that? |
Ok just had a chance to have a look and yes it’s the bolts on the motor all 3 have snapped the last one is when looks like it has just gone ,I also found one of the bolts that hold the rack together has come out ….EVERYBODY CHECK YOUR RACKS…..so replacement steering rack it is |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8509 ![]() ![]() ![]() |
Blimey, that's not good, is the rack cracked...???
that’s one way of putting it |
E500 Member Since: 10 Sep 2024 Location: Hertfordshire Posts: 86 ![]() ![]() |
Wow, what a ballache.
Got some more photos from the corrosion this has been going on for some time was thinking of just replacing the motor but looking at the corrosion think it’s best to do the whole rack seen as the wife drives it as well and the grandkids …….and to think over Christmas we were on the motorway from Plymouth to darlington …….hate to think what would of happened at those speeds not good not good at all
