![]() | Home > Maintenance & Mods (L322) > Keeping the turbos in good nick |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 900 ![]() ![]() ![]() |
I buy my ZX1 from Amazon, £17 for each 250ml bottle ( I buy 3 to say money at the same time ) https://www.amazon.co.uk/Extralube-Anti-Fr...3Y?ie=UTF8 The good thing is that ZX1 is not an "Oil Additive" - it's anti friction treatment eliminator, so if we believe what they say on their website it does not change the properties of the oil at all ![]() https://www.team-zx1.com/what-is-zx1.html It is often confused with "Oil Additives for engines", when, in fact EXTRALUBE ZX1 Micro Oil is a Metal Treatment therefore different to other engine treatments available on the market today. It does not contain particulates such as Teflon or P.T.F.E. Molybdenum or Zinc Dialkyldithiophosphate (as quoted by honest john) a common cause of blocked filters and airways which has a toxisty level between milk and garden soil and it is not copper corrosive. EXTRALUBE ZX1 Micro Oil Metal Treatment does not change the properties of the oil, or other native lubricant, but chemically bonds to the metal surfaces, modifying the friction surfaces of the metal. It allows the oil (Team ZX1 do not wish to rubbish the oil currently being used, as it needs this oil) to do its job even better and the significant benefits result in:- Lowered carbon exhaust emissions Increased MPG Excellent cold start protection and anti-wear performance Protects immediately up to 25,000 miles Impregnated wearing surfaces Virtually eliminated friction. Last edited by pcourtney on 13th Jan 2025 12:25pm. Edited 1 time in total |
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 166 ![]() ![]() ![]() |
Pcourtney, thanks for the link and interesting way of adding to your engine. Out of interest which version do you have and how long have you used ZX1 for? 2012 4.4 TDV8 Vogue Santorini black ivory leather |
in the Amazon link 250ml bottle
According to the saftey data sheet it's an EP addative in an oil carrier. EP addatives are common in gearboxes where high loads on small contact areas are common but not sure where this would be needed in an engine and certainly not in a turbo. Not many ( if any) reports of engine wear due to insufficient standard lubrication and servicing but if £50 makes you happy and keeps a UK business going then why not. At the quantities specified it's unlikley that whatever it contains will be enough to contribute to ash load or damage the main CAT and the one that's part of the DPF. 2012 TDV8 Vogue (L322) |
Sorry, when I asked which version I should have added 'engine'!
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7905 ![]() ![]() ![]() |
Click on the car on the left…. If they have filled in that bit of their profile….
Previous cars : 2003 Range Rover Vogue TD6 1999 Discovery Td5 ES 1995 BMW M5 3.8 6 speed 1992 Range Rover 3.9 Efi Vogue 1992 BMW M5 3.8 1988 BMW 735i SE 1989 Ford Sierra XR4x4 2.9i 1981 Ford Fiesta Supersport |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 289 ![]() ![]() ![]() |
I’m a fan of ZX1 having used it in both cars and performance bikes for a while. My understanding ( I’m not a chemist by training ) is that it bonds at the molecular level where friction occurs.
Ramblinman, seems we follow as very similar regime albeit I have not used ZX1 in my bikes yet. 2012 4.4 TDV8 Vogue Santorini black ivory leather |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2616 ![]() ![]() |
If these additives do anything, why don’t oil and car manufacturers use and recommend them? |
Same manufacturers who, (not aimed specifically at any particular manufacturer)
The oil industry spends huge amounts on R&D, but instead of revolutionary cheap, permanent molecular-bonding-at-normal-operating-temperature, friction-reducing magic additives that can be poured into any bit of the car, they come up with stuff like Magnatec. I know it’s easy to be cynical, but… |
Manufacturers don't recomend addatives for very good reasons - they either don't know what it contains or do know and know it will harm the engine. IMO addatives are like exotic speaker cables - snake oil with no measurable benefit. 2012 TDV8 Vogue (L322) |
Jaygee as someone who has spent silly amounts on speaker cables i totally agree they are snake oil.
If these adatives reduced internal friction as claimed then it would be easy enough to measure the mpg and power gains as internal engine friction is a significant load. 2012 TDV8 Vogue (L322) |
