Home > Maintenance & Mods (L322) > Keeping the turbos in good nick
Page 3 of 3 <123
Eastsoutheast
United Kingdom 2012 Range Rover Vogue TDV8 Santorini Black
Jay, your knowledge and experience is invaluable here so I totally respect your view on oil additives. Your comments have motivated me to do lots more reading on the subject and may save me money in the future. 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #709202 15th Jan 2025 3:02pm
JayGee
Don't tell anybody but I have some on order for my next oil change......... 2012 TDV8 Vogue (L322)
Post #709203 15th Jan 2025 3:19pm
D3Jon
I wonder if anyone has ever done a chemical analysis of the ZX1 product itself? Just to see what's in it?
Their website states it's "re-engineered hydrocarbon molecules" - I'd be very interested to understand how it's re-engineered and just what that process entails. Engine lubricating oil is already re-engineered isn't it?
Their web-site alone puts me off the stuff.
For example: MOT test emissions results taken almost 1 year apart to demonstrate reductions in CO, for example. Perhaps the car in question (a Corsa) had an air filter change in the intervening 11 months, or the test equipment / testing station wasn't the same?
Rather unbelievably, on one page of their rather sprawling web-site they actually state that their product is not associated whatsoever with "Snake Oil"! Shocked Laughing
Good luck to them if they can sell this stuff, but it wouldn't be going anywhere near the crankcase of my vehicles. Just personal choice.
My engine longevity programme will continue to be regular 6 monthly oil changes using quality oil. I'll leave the definitely-not-'Snake Oil' products for someone else to use! 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #709310 16th Jan 2025 12:44pm
andygts
On the subject of the original question about turbos - use them, don't buy a range rover and then try to make a 4.4v8 do 40+mpg
on the subject of oil I'll add my 2p
Manufacturer will specify oil additives for engines BUT it's already in the oil you buy, do your next service on halfords homebrand 5w30 and do a few 1000miles with it....you'll soon have some faults popping up, probably starting with the DPF as the oil will have a high SAPS content.
Do your next service with the correct spec oil for the engine eg 4.4sdv8 5w30 C1 oil and the additives etc are already in it and you should be trouble free.
The thing that kills modern engines is all the emissions crap they put on them. Engines like to breath, restricting them and force feeding them their own exhaust gases doesn't do them any good.
Take the intake off a modern engine and compare it to a similar pre EGR engine and compare the carbon build up.
I've seen some engines to the point where the manifolds have that much carbon in them they've blocked up and the car won't start.
If you think I'm talking out of my arse go pull your MAP sensor out and look how much Censored is on it, give it a good clean with some carb cleaner and see the difference, I always did this as part of my services as my short commute accelerated the build up. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #709342 16th Jan 2025 3:35pm
Page 3 of 3 <123
