![]() | Home > Maintenance & Mods (L322) > Keeping the turbos in good nick |
It's very, very rare that these turbo's fail. Regular oil changes at 5-7k miles with the correct C1 oil takes care of the servicing side and not driving hard until the oil temps are high enough to perform optimaly (note that the coolant gets up to temp way before the oil and on cold days it may be 1/2 hour before oil is up to temp) Excercising the 2nd turbo won't do anything for the care of the actual turbo but may clear accumulated oil and prevent the smoke issue and keep the changover valve from sticking on pre MY12 cars. 2012 TDV8 Vogue (L322) |
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 165 ![]() ![]() ![]() |
I am in no way qualified to answer this from a technical perspective but my view which I follow,
markh1 Member Since: 12 Dec 2024 Location: surrey Posts: 23 ![]() ![]() |
Thanks for the responses and good to know turbo failure is rare!
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
On the 4.4 TDV8 turbo failure is very rare.
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1231 ![]() ![]() ![]() |
As mentioned above, oil / filter changes, and after a longer journey especially at higher speed, after stopping the car allow the engine to cool a little before switching off will help. Starting an engine and driving Italian style from cold will not be good for the engine |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7894 ![]() ![]() ![]() |
Yes, the pre heater just does the coolant… agree re all the comments above.
No need to idle / let the engine cool before turning off as this is outdated practice from the days before water cooled turbos and synthetic oil. I don't subscribe to the notion the 2nd turbo needs regular excercise to keep it working either as you have to remember that every time you request large loads from the engine it's putting extra stress on the components which are now 13+ years old. Look into the topic of cracked inlet manifolds and how much they cost to replace and then see if you think applying 1.5 bar of boost to old plastic is a good idea everytime you go for a drive...... 2012 TDV8 Vogue (L322) |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 512 ![]() ![]() |
Confucius says... Never buy a car from a person who lives on top of a steep hill. Unless they have the patience to let the turbo's cool after driving home...
Synthetic base stock's + watercooled turbo exhaust housings are the very reason turbo's don't fail like they used to ( I owned early turbo charged cars that did so it's not somthing I picked up down the pub |
Ah, just edited my post to explain reason I like to cool them down. Posts crossed in the ether! |
To be honest I always idle for a few seconds before shutdown as well but it's just an unshakable habit from owning early turbo cars where it was an essential procedure. I remember seeing the turbo glowing red once after stopping an early 80's Saab at a service station on the motorway. 2012 TDV8 Vogue (L322) |
Does anyone here use any oil additive for added protection?
JLR specificaly advises against oil addatives. This is especialy true with DPF equipped cars where addatives may add to the ash load. 2012 TDV8 Vogue (L322) |
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 123 ![]() ![]() ![]() |
It's funny, kinda, when it comes to turbo's and engine longevity in general, people recommend synthetic oils while their beloved (& outdated |
