Home > In Car Electronics (L322) > CarPlay for under £100
Page 5 of 5 <12345
I was just fishing about for a car play solution to my 2016. I spotted that there is a car play plug in module available for the 322.
https://unique-ad.co.uk/product/wireless-a...2009-2012/
I’ve not used these peeps before so it’s not a recommendation just a shout to say they are available.
Not cheap tho….. There is nothing that can't be fixed with a hammer😜😜
Post #708325 5th Jan 2025 9:03am
RobsterPC
Plug and play is a bit of a misnomer for the UAD solution. Check out the Sam Motor and Machine 2 part video on how he did his. It's a dash out job plus disassemble the head unit to then plug and play the solution. I'd have this but couldn't be bothered in the end.
Post #708415 5th Jan 2025 10:17pm
madnessgonemad
I think this solution is quite difficult and expensive. Also, you are limited by the quality and size of the original screen with quite poor resolution by today’s standards.
Post #708436 6th Jan 2025 11:12am
jimmie
Poland 2004 Range Rover Vogue 4.4 V8 Epsom Green
and be prepared that after about year touch control for android / carplay mode will no longer work
Post #708680 9th Jan 2025 7:03am
AlexTVR
With thanks to a few posts in this forum and RobsterPC have my Aliexpress Christmas gift installed and running.
1.5mm aluminium sheet and some heavy duty Velcro from Amazon. Sheet cut to suit my unit, about 3-4 inches slot in easily between dash top and original ICE unit. Dashcam is still at a good height, unit is within easy reach.
Few things worth considering for people going this route, where the power input is on device. Mine is on bottom, but the unit came with power lead with a 90deg plug that sends lead out from the back of the unit - if I really wanted a tidy install I’d try and get a different power lead, maybe even run through dashtop vent to fuse box. Power is the only lead I’m using for my setup, run to cig lighter socket at rear of centre console.
I’m using CarPlay with iPhone, and that linked perfectly with unit (wireless), I’m then using my BT Bovee device for sound* and also BT to original Landrover unit for phone calls. All works seamlessly except Siri, she goes via the original Landrover connection so it looks like I’m phoning Siri every time, and doesn’t sound nice. I’ve tried different ways but that’s the only way I can hear and interact with Siri. Waze/Music/Maps all send sound via Bovee and sound really good.
The unit powers up when I unlock the car, and CarPlay is usually up and running by the time I’m in and ready to start. Overall very happy with cheap and easy setup. 2010 Supercharged
Post #708950 12th Jan 2025 4:20pm
Page 5 of 5 <12345
