![]() | Home > In Car Electronics (L322) > No volume control on steering wheel, everything else works. |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 405 ![]() ![]() ![]() |
Hi, mine did the exact same thing a few times, I sprayed a liberal amount of contact cleaner around the switch and it’s never given me any trouble since. I’ve also had the steering wheel off though so might be a solution that both options.
Covbandit Member Since: 11 Jan 2016 Location: Coventry Posts: 108 ![]() ![]() ![]() |
Thanks pal, was just your volume affected? It did it again today, parked up no volume control, mrs popped in morrisons and when she came out, started car and worked again? Will give it a go with some cleaner. |
Yes exactly the same, would be just the volume control and then would work again after restarting.
Perfect, will give it a ho, had steering wheel off prev l322.
RRfranz Member Since: 25 Dec 2023 Location: Tirol Posts: 13 ![]() ![]() ![]() |
Hello!
Thank you, I have had the steeringvwheel off and cleaned but , still having same issues, it only started when the cd changer stopped working, I thought it was just a coincidence, but I think thats my next step, thanks |
There is a great post by klf 400 under the title: 2011 CD changer invalid disc |
