Home > In Car Electronics (L322) > No volume control on steering wheel, everything else works.
Covbandit
United Kingdom 2003 Range Rover Vogue 4.4 V8 Oslo Blue
As in the title everything on the steering wheel works except the volume up and down, has been working fine since I bought it, as the horn, telephone, cruise etc all works, I am doubtful its the clock spring/steering wheel coupling. As sometimes after a full shutdown it will work again. Coincidently at the same time, my cd player has stopped recognising discs, comes up as invalid disc. Whetehr the two are related I am not sure, I have yet to check the back end. The car is an 08 plate however has the later type seats and also the later type bluetooth that is not a retrofit. Any help would be appreciated, thanks
Post #707813 29th Dec 2024 2:33pm
Scouse Exile
Hi, mine did the exact same thing a few times, I sprayed a liberal amount of contact cleaner around the switch and it’s never given me any trouble since. I’ve also had the steering wheel off though so might be a solution that both options.
Taking the steering wheel off is easier than it seems.
Jon
Post #707814 29th Dec 2024 2:52pm
Covbandit
Thanks pal, was just your volume affected? It did it again today, parked up no volume control, mrs popped in morrisons and when she came out, started car and worked again? Will give it a go with some cleaner.
Post #707815 29th Dec 2024 2:56pm
Scouse Exile
Yes exactly the same, would be just the volume control and then would work again after restarting.
Hasn’t done it for a year or more now. With the steering wheel off you can take the unit off and dig deeper if necessary.
J
Post #707817 29th Dec 2024 3:48pm
Covbandit
Perfect, will give it a ho, had steering wheel off prev l322.
Thanks
Post #707818 29th Dec 2024 3:54pm
RRfranz
Austria 2011 Range Rover Vogue TDV8 Santorini Black
Hello!
The volume control didn't work on my L322 (2011) either. The CD changer was to blame.
Post #708202 3rd Jan 2025 5:49pm
Covbandit
Thank you, I have had the steeringvwheel off and cleaned but , still having same issues, it only started when the cd changer stopped working, I thought it was just a coincidence, but I think thats my next step, thanks
Post #708209 3rd Jan 2025 7:18pm
RRfranz
There is a great post by klf 400 under the title: 2011 CD changer invalid disc
Post #708238 4th Jan 2025 6:25am
