Home > Technical (L322) > Second Turbo 4.4 TDV8
pcourtney
I am trying to figure out when my second turbo kicks in, as in driving down the motorway in auto mode and climbing the speed slowly up to say 100mph
I just cannot hear it, I hear the first turbo faintly with its weak high pitch whistle but when I say its faint, you really have to listen for it, but at what speed do you think the second turbo kicks in - I was expecting the turbo noise to be discernibly louder ?
I have a GAP IID, would it give me some data if the second turbo is working OK ?
Also is the primary turbo bigger than the secondary turbo ?
Post #707611 25th Dec 2024 8:52pm
kevinp
Second turbo doesn't activate untill about 2400rpm so even at 100mph it will still be at idle I would have thought.
Post #707613 25th Dec 2024 9:05pm
mjdronfield
It’s not speed, it’s rpm… / engine load / throttle position.
You will feel a good shove when it kicks in, keep your foot in it so it holds the gear. If you take your foot back it will change up and the revs will drop.
If you just drive on light throttle it won’t spin up..
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #707619 25th Dec 2024 11:07pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Use the flappy paddles if you want to keep revs up without being so foot heavy …
Post #707633 26th Dec 2024 10:20am
pcourtney
OK, using the paddle gears I got to hear the second turbo, not as much extra oomphhh or noise as I was expecting, but its there sure enough, I also came onto the slip road of the motorway and maintained about 2800rpm for about 60 seconds to see how much smoke out of the back I could see, and nothing there, so that's a good sign Smile
Have been told that its a good idea to get the secondary turbo to kick in every so often, especially if your normal drive or commute does not activate it !
Post #707638 26th Dec 2024 1:23pm
mjdronfield
Yes, I try and get mine going at least once every trip.
Car should be pretty quick if you let it rev to 4000 rpm plus etc… you should def feel the shove.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #707639 26th Dec 2024 1:31pm
JayGee
On the pre MY12 cars with the old style crossover valve 'regular excercise' is a good idea. The 2nd turbo is smaller than the primary one and just keeps the power going further up the rev range. I don't notice a sudden jump in power or any change in noise and it's all very smoothly integrated. 2012 TDV8 Vogue (L322)
Post #707642 26th Dec 2024 3:04pm
Rambles
https://www.automobile-catalog.com/curve/2...#gsc.tab=0
Flat torque curve
So no jump in power…but a linear increase in power with revs
Torque starts falling off rapidly after 3250 rpm
Mine feels as though it runs out of puff around 3500 rpm
For me…2500 - 3500 rpm is where the motor feels very comfortable for “making progress “
Post #707665 27th Dec 2024 10:58am
DrRob
Use the second turbo daily when warm to keep the crossover valve working well….
As said, rev above 2500rpm for it to kick in Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #707672 27th Dec 2024 1:04pm
JayGee
Be carefull what you class as warm. The oil temp is what it important to get up to temp not the coolant. If you monitor oil temps with your GAP IID tool you will be suprised how long this takes esp on cold days. 2012 TDV8 Vogue (L322)
Post #707681 27th Dec 2024 2:41pm
