Home > Technical (L322) > Second Turbo 4.4 TDV8 |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1216 |
Second turbo doesn't activate untill about 2400rpm so even at 100mph it will still be at idle I would have thought. |
25th Dec 2024 9:05pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7805 |
It’s not speed, it’s rpm… / engine load / throttle position.
25th Dec 2024 11:07pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 804 |
Use the flappy paddles if you want to keep revs up without being so foot heavy … |
26th Dec 2024 10:20am |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 817 |
OK, using the paddle gears I got to hear the second turbo, not as much extra oomphhh or noise as I was expecting, but its there sure enough, I also came onto the slip road of the motorway and maintained about 2800rpm for about 60 seconds to see how much smoke out of the back I could see, and nothing there, so that's a good sign
26th Dec 2024 1:23pm |
Yes, I try and get mine going at least once every trip.
26th Dec 2024 1:31pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3248 |
On the pre MY12 cars with the old style crossover valve 'regular excercise' is a good idea. The 2nd turbo is smaller than the primary one and just keeps the power going further up the rev range. I don't notice a sudden jump in power or any change in noise and it's all very smoothly integrated. 2012 TDV8 Vogue (L322) |
26th Dec 2024 3:04pm |
