Home > Technical (L322) > FBH Issue? Fault B1D24-64 (TDV8 4.4)
FrankRizzo
Germany 2012 Range Rover Vogue 4.4 V8 Santorini Black
Surprised to see this code hasn't cropped up on here before. One of the permanent faults on my GAP tool is this:
B1D24-64 - Glow plug circuit - Algorithm based failure - signal plausibility failure (2B)
A couple of threads on the Disco forum suggest it refers to the glow plug in the FBH.
I assume it means the glow plug is faulty. Might explain why my FBH never puts out anything more than luke-warm air, not that I ever use it very much.
Can the FHB glow plug be replaced or does the whole FBH need replacing? 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
2008 Vogue 3.6 TDV8 automatic (LHD), Java Black
Post #706509 9th Dec 2024 11:49pm
Strobe84
It's that time of year when all of the winter comforts of the L322 decide to give up! Mine is also throwing this code at the moment. Have you got anywhere with it before I fire up the parts cannon?
Post #706537 10th Dec 2024 11:10am
FrankRizzo
No, I've only seen the fault since I bought the GAP tool two months ago. I don't want to buy a new FBH if the glow plug - if that is truly the problem - can be replaced independently. 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
Post #706569 10th Dec 2024 10:05pm
Strobe84
I've seen kits online which include bolts, a gasket and a plug but not sure if it's the right part.
Post #706578 11th Dec 2024 7:36am
SpitfireS
Germany 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
After googling a bit:
The FBH is a Webasto Thermo Top C
Some posts (not on ffrr) suggest it's not that hard to remove the Webasto and replace the glow plug.
(German engineering... Wink )
Does yours make this light whirring noise when the FBH fan speeds up/down? 2012 4.4TDV8
2000 Honda S2000
Post #707575 24th Dec 2024 1:46pm
