FBH Issue? Fault B1D24-64 (TDV8 4.4) | |
Surprised to see this code hasn't cropped up on here before. One of the permanent faults on my GAP tool is this:
B1D24-64 - Glow plug circuit - Algorithm based failure - signal plausibility failure (2B)
A couple of threads on the Disco forum suggest it refers to the glow plug in the FBH.
I assume it means the glow plug is faulty. Might explain why my FBH never puts out anything more than luke-warm air, not that I ever use it very much.
Can the FHB glow plug be replaced or does the whole FBH need replacing? 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
2008 Vogue 3.6 TDV8 automatic (LHD), Java Black
