Home > Maintenance & Mods (L322) > Small break fluid leak - Can I drive the car? |
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 316 |
Yes, it's been bled wrong. I'd expect them to use a power bleeder on something like this. If they're doing it manually, the old fashioned way, it might be a lot harder to do.
20th Dec 2024 12:46pm |
RangeRov Member Since: 24 Jun 2019 Location: Stockholm Posts: 55 |
They did say, before they started the job, that it would take 2 hours per corner, or if it was 2 hours totally, just to remove the air. I found it quite a long time but I don't know as I've never done it mysef, only been watching DYI videos for fun.
20th Dec 2024 1:04pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1475 |
Nope, they’ll need to run the ABS pump whilst bleeding, I bet they didn’t!
20th Dec 2024 2:13pm |
Thanks! I can give them this as an advice to them.
20th Dec 2024 3:27pm |
Andra Member Since: 22 Sep 2015 Location: Scotland Posts: 77 |
A diagnostic device is required to activate the abs pump whilst bleeding the brakes .
20th Dec 2024 3:40pm |
Each time the abs pump is activated it will probably operate for about 30 seconds and when it stops then keep the bleed valve open until another 150ml of fluid has flushed out |
20th Dec 2024 5:17pm |
Need a correct type charger to fully charge the battery and then switch the charger to power supply mode when activating the abs pump for brake bleeding . Something that can supply 25 amps and preferably much more amps . Give the battery time to recover after bleeding each caliper . |
21st Dec 2024 1:00am |
