Home > Maintenance & Mods (L322) > Small break fluid leak - Can I drive the car? |
Stuart- Member Since: 16 Dec 2017 Location: UK and Hong Kong Posts: 338 |
Yes, it's been bled wrong. I'd expect them to use a power bleeder on something like this. If they're doing it manually, the old fashioned way, it might be a lot harder to do.
20th Dec 2024 12:46pm |
RangeRov Member Since: 24 Jun 2019 Location: Stockholm Posts: 57 |
They did say, before they started the job, that it would take 2 hours per corner, or if it was 2 hours totally, just to remove the air. I found it quite a long time but I don't know as I've never done it mysef, only been watching DYI videos for fun.
20th Dec 2024 1:04pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1561 |
Nope, they’ll need to run the ABS pump whilst bleeding, I bet they didn’t!
20th Dec 2024 2:13pm |
Thanks! I can give them this as an advice to them.
20th Dec 2024 3:27pm |
Andra Member Since: 22 Sep 2015 Location: Scotland Posts: 83 |
A diagnostic device is required to activate the abs pump whilst bleeding the brakes .
20th Dec 2024 3:40pm |
Each time the abs pump is activated it will probably operate for about 30 seconds and when it stops then keep the bleed valve open until another 150ml of fluid has flushed out |
20th Dec 2024 5:17pm |
Need a correct type charger to fully charge the battery and then switch the charger to power supply mode when activating the abs pump for brake bleeding . Something that can supply 25 amps and preferably much more amps . Give the battery time to recover after bleeding each caliper . |
21st Dec 2024 1:00am |
It sounds like the garage will not be able to replicate this method to be honest.
22nd Dec 2024 11:10am |
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 116 |
Years and years ago, driving an old 500 Euro Golf to work - as a temporary replacement car - I had to brake, not even very hard and all of a sudden the pedal went to the bottom.
22nd Dec 2024 12:21pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3141 |
I’ve successfully bled the brakes on several L322’s now.
22nd Dec 2024 2:41pm |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 503 |
I agree with David,
22nd Dec 2024 3:11pm |
Thanks all.
23rd Dec 2024 6:44am |
To RangeRov: you've got to find a way to tell your workshop in a friendly manner they are talking out of their ass.
23rd Dec 2024 7:37am |
That is utter & total rubbish! I changed all 4 calipers and flexible lines on my L405, and bled with a pressure bleeder in the correct sequence, but the pedal remained spongy (even though I’d clamped the old hoses it was impossible not to get air in fitting the new hoses), (I wasn’t aware of the ABS thing at the time, and didn’t have a GAP tool then anyway) I took it very slowly to my (very local) LR specialist Indy, who did it using Pathfinder to run the ABS pump, it came back with a nice, solid pedal, but £100 poorer. Soft Pedal = Job not done properly!!! “If it ain’t broke, don’t fix it” -where’s the fun in that? |
23rd Dec 2024 9:41am |
