Home > Technical (L405) > Will not go out of P!?! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35474 |
are you pressing the foot brake down enough?
19th Nov 2024 8:34pm |
JLS Member Since: 25 Jan 2016 Location: Oslo Posts: 23 |
Yes. Can see the brake light shine too…. So the switch is ok, if it’s the same switch, and not a separte one for the box?
19th Nov 2024 9:13pm |
A quick update. The P lock issue is solved with some gaffa tape The solution nicked from YouTube… But, a tip for the other ones that have, or will have, the same problem: Follow the workshop manual to dismantle the gear selector unit, and not the one that you find on YouTube (the guy loosens the whole centre console, pulls it backwards and access the gear selector uniot from the front.). That´s a way to complicated way to do it! It´s supposed to be accessed/opened from the rear, leaving the console where it is!
8th Dec 2024 8:23am |
Thanks for the update ... - .- -.
8th Dec 2024 9:04am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1408 |
Funnily enough mine did this the other day with my wife. She claimed not to have tried to turn the selector before it rose up fully but I don’t know
10th Dec 2024 10:31pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3756 |
Speaking from experience do not leave this - get the selector changed, an intermittent fault soon turns into a permanent one and it will definitely leave you stranded - most likely in a very inconvenient or dangerous place - doing a U turn, in a road for example or in a car park leaving you stranded in the middle of the road blocking it and causing a huge amount of stress to not only you but other drivers being also blocked in.
11th Dec 2024 3:59am |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1434 |
seems like the sensible thing might be for us all to purchase a spare and have in the workshop for that very day!! |
11th Dec 2024 4:43pm |
£150 to £300 is a lot for a spare just to sit around. a roll of gaffer tape might be better value after all! V8 or else ... |
11th Dec 2024 7:25pm |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1254 |
I have bought the gaffer tape, where do i put it 2018 SE SDV8 4.4 Byron Blue |
12th Dec 2024 12:14am |
Nasher Member Since: 30 Sep 2009 Location: Down South Posts: 54 |
Yep, Don't leave this, it will get worse and at the most inconvenient time. When the rotary selector in my D4 decided to stop rotating I'd just reversed out of a parking bay in a car park and was stuck in reverse blocking the road, unable to go forward again or even select neutral to roll it out the way. I turned the ignition off hoping it would sort itself out but it didn't. I wasn't going anywhere. I had an embarrassing 15 mins whilst I stripped out the centre console and split the halves of the module to push the lock back with a costa stirring stick. I was lucky the owner of the car I'd reversed up to and was blocking in didn't return in that time. And I'm obviously lucky I have the tools in the car and am able to do the work. The replacement I modified before fitment with the 'cable Tie mod' which enables me to pull the tail of a cable tie tucked up just under the console to pull the lock back if needed. Last edited by Nasher on 12th Dec 2024 11:11am. Edited 1 time in total |
12th Dec 2024 9:09am |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 166 |
So now, as well as worrying about: blocked DPFs, regens, snapping crankshafts, stuck EGR valves and various turbo problems I have to worry about it sticking in gear. Oh well, more sleepless nights till I find out where to put the gaffer tape. 😕 |
12th Dec 2024 11:05am |
dont forget the hammer... ... - .- -.
12th Dec 2024 3:22pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1569 |
Ah! I get it.
12th Dec 2024 4:05pm |
My wife claimed it happened again. I get the in car, and it works perfectly.
12th Dec 2024 8:01pm |
