![]() | Home > Technical (L405) > Will not go out of P!?! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35593 ![]() ![]() |
are you pressing the foot brake down enough?
JLS Member Since: 25 Jan 2016 Location: Oslo Posts: 23 ![]() ![]() |
Yes. Can see the brake light shine too…. So the switch is ok, if it’s the same switch, and not a separte one for the box?
A quick update. The P lock issue is solved with some gaffa tape |
Thanks for the update |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1450 ![]() ![]() |
Funnily enough mine did this the other day with my wife. She claimed not to have tried to turn the selector before it rose up fully but I don’t know |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3778 ![]() ![]() |
Speaking from experience do not leave this - get the selector changed, an intermittent fault soon turns into a permanent one and it will definitely leave you stranded - most likely in a very inconvenient or dangerous place - doing a U turn, in a road for example or in a car park leaving you stranded in the middle of the road blocking it and causing a huge amount of stress to not only you but other drivers being also blocked in.
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1458 ![]() ![]() ![]() |
seems like the sensible thing might be for us all to purchase a spare and have in the workshop for that very day!! |
£150 to £300 is a lot for a spare just to sit around. a roll of gaffer tape might be better value after all! V8 or else ... |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1307 ![]() ![]() |
I have bought the gaffer tape, where do i put it |
Nasher Member Since: 30 Sep 2009 Location: Down South Posts: 54 ![]() |
Yep, Don't leave this, it will get worse and at the most inconvenient time. When the rotary selector in my D4 decided to stop rotating I'd just reversed out of a parking bay in a car park and was stuck in reverse blocking the road, unable to go forward again or even select neutral to roll it out the way. I turned the ignition off hoping it would sort itself out but it didn't. I wasn't going anywhere. I had an embarrassing 15 mins whilst I stripped out the centre console and split the halves of the module to push the lock back with a costa stirring stick. I was lucky the owner of the car I'd reversed up to and was blocking in didn't return in that time. And I'm obviously lucky I have the tools in the car and am able to do the work. The replacement I modified before fitment with the 'cable Tie mod' which enables me to pull the tail of a cable tie tucked up just under the console to pull the lock back if needed. Last edited by Nasher on 12th Dec 2024 12:11pm. Edited 1 time in total |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 174 ![]() ![]() ![]() |
So now, as well as worrying about: blocked DPFs, regens, snapping crankshafts, stuck EGR valves and various turbo problems I have to worry about it sticking in gear. Oh well, more sleepless nights till I find out where to put the gaffer tape. 😕 |
dont forget the hammer... |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1655 ![]() ![]() ![]() |
Ah! I get it.
My wife claimed it happened again. I get the in car, and it works perfectly.
