Home > Maintenance & Mods (L322) > Rear suspension odd issue that I can't fathom
nick4275
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
I'll try to keep it short. 2007 3.6 TDV8 - 273K Miles.
MOT advisory for last 2 years for rear upper suspension bushes. Bit the bullet and replaced them. MOT passed, no advisories.
Thought it wise to go for a Hunter 4 wheel alignment due to new suspension parts and this is where the fun starts.
Garage couldn't get the rear tie rod cam bolts to move at all. So another bullet bitten, two new tie rods. Back to the garage who say the right rear wheel is toe-ing out and there's not enough adjustment provided by the cam bolt to bring it back into line. They suggested maybe fit an adjustable tie-rod (which I'm not even sure exists).
Wondered if anyone else has had anything similar ?
Just as a note: I'm pretty sure I can hear a "donk" type noise when the right rear corner goes under load. I've pulled and pushed at all the suspension joints/bushes but can't see or feel anything wrong. The old girl has done 273K miles so I suspect most of the rubber in all of the bushes is well past it's sell by date. Previous life - 2012 L320 SDV6 - Got divorced, say no more!
Previous life - 2014 L494 SDV6 - Got nicked, without keys, watched it go !
The Duchess - 2007 L322 TDV8 3.6 Autobiography with 270K miles on the clock
The Bonkers One - Audi SQ7 V8 4L TT - It will pull your face off.
Post #706593 11th Dec 2024 10:14am
I'd put my money on subframe mounts failing.... something is wrong, that's for sure.... Pete
Post #706621 11th Dec 2024 2:58pm
nick4275
Cheers Pete,
My parking brake is also dead - so two reasons to drop the sub-frame now !
Thanks for the pointer Previous life - 2012 L320 SDV6 - Got divorced, say no more!
Post #706625 11th Dec 2024 3:36pm
Check all the suspension arms first, one maybe bent, they don't have to bend much to chuck the alignment out... Pete
Post #706632 11th Dec 2024 5:02pm
kevinp
I put new tie rods on mine and the cams were at the limit with one wheel slightly out of adjustment but the tyres are not being affected.
I was going to weld a bit of extra metal on the cams but hav'nt got round to doing it yet.
Post #706637 11th Dec 2024 5:54pm
