Home > Technical (L322) > Battery drain,,,again!
John-suusex
ok, Think I'm getting close to my limits here. 08 3.6. My battery will be flat in under 24hrs. Having done a quick check would seem i have drain of around 1.2 amps. It is on a new battery.
I've had a look at some of the posts here and will try the odd ones. Not going the parts cannon route however have replaced the final stage resistor.
Have noticed on very odd times the radio screen looks faintly lit, bluetooth optic bypassed.
Is there a definitive post to follow? I haven't as yet found it?
Tia 2008 TDv8 Vogue in Java black x2
2000 P38 They aren't all bad!
1996 D1 3.9 es
1996 Volvo 850 GLT
Post #706342 7th Dec 2024 7:18pm
Eastsoutheast
United Kingdom 2012 Range Rover Vogue TDV8 Santorini Black
I am not a mechanic or electrician of any sort but just sharing something I have read whilst researching a battery drain myself.
I read that a failed alternator on these cars has the effect of placing a metal object across both battery terminals.
Maybe worth investigating as I would like to think it would be quite easy for an auto electrician to confirm or rule out a failed or failing alternator. Good luck 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #706347 7th Dec 2024 7:55pm
Scouse Exile
Try this;
In theory you should be able to target it down to a small number of components if not the exact item.
J
Post #706349 7th Dec 2024 8:05pm
John-suusex
thanks 2008 TDv8 Vogue in Java black x2
1996 D1 3.9 es
1996 Volvo 850 GLT
Post #706354 7th Dec 2024 8:46pm
