Home > My Range Rover > My 2012 Westminster TDV8 |
RobsterPC Member Since: 14 Oct 2024 Location: Kent Posts: 115 |
New high and low beam bulbs on order, hopefully they'll get fitted this week.
2nd Dec 2024 5:14pm |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 609 |
Hi Robster,
2nd Dec 2024 9:31pm |
Part LR009645
2nd Dec 2024 10:42pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3138 |
Would be interested in pictures of how easily the seat foam can be replaced if you don't mind! I'd be tempted to do my drivers side one on the 5.0 as the seat isn't quite as good as the 26k mile 4.4 TDV8 we've got. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
3rd Dec 2024 12:43am |
Yes, I'll share some pictures as it happens, assuming I don't damage myself removing the seat! The workshop manual has a section on this too:
3rd Dec 2024 9:49am |
Cripes that's a bit pricey, I' think I'll have a go at steaming first after I strip it down.
3rd Dec 2024 5:04pm |
Currently in for a gearbox mega flush and investigation of leaking coolant. Apparently the thermostat housing is leaking. Not looking forward to the bill for this one. |
6th Dec 2024 11:38am |
Gearbox flush done and coolant leak investigated at Dartford Transmissions. They also gave it a good going over but didn't report any more faults, which was good as it was a punchy bill! The gearbox definitely feels smoother now when cold, less clunky when pulling away. It had done 30k miles since the last gearbox oil change but that was not a full flush.
13th Dec 2024 4:08pm |
I love the easy jobs. Before I tackle anything else I wanted to improve the headlights. Time for some Osram Xenarcs for the low beam and some Bevinsee V55s for the high beam. Both from AliExpress.
14th Dec 2024 1:07pm |
After a couple of drives in the dark I can report that the dipped lights work well but the high beams are amazing! Proper floodlights and so much safer for driving on dark country roads. Hopefully they last well, so far I'd massively recommend them. |
14th Dec 2024 9:13pm |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 394 |
Out of interest, exactly which items did you buy as the Benvinsee ones seem to have options for 150w and 120w
14th Dec 2024 10:07pm |
I bought the Bevinsee V55 H7s:
15th Dec 2024 9:56pm |
Thanks, might give them a try.
15th Dec 2024 10:03pm |
Fixed the broken heated seat air guide with a new one from eBay. Also replaced the driver's seat base foam. With a trip to the Alps coming up, having a comfy chair to do over one thousand miles in is going to be important. |
28th Dec 2024 5:41pm |
