![]() | Home > Technical (L322) > Air suspension not working due to "open door" |
Marcus76 Member Since: 03 Jul 2022 Location: Baden Württemberg Posts: 10 ![]() ![]() |
Hello,
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 594 ![]() ![]() ![]() |
Thanks Marcus I will check that.
Checked the bonnet switch today and can confirm that it does not inhibit raising or lowering of the suspension and neither does the tailgate.
tspd Member Since: 13 May 2024 Location: London Posts: 56 ![]() ![]() ![]() |
Mine did this for the first time last week. All doors were closed as it beeped and flashed when locking.
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 339 ![]() ![]() ![]() |
When I had my first FFRR the suspension did not work but I diagnosed (without a code reader) that the courtesy lights did not activate when I used the passenger rear door. I replaced the door lock mechanism and everything then worked. Is it possible that you have a faulty microswitch in one of the door locks?
