Home > Technical (L322) > Air suspension not working due to "open door"
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
A bit strange I thought, but the open door message does not pop up on normal driving so the car knows the door are are closed.
But when I select Access mode the message pops up "close doors etc"
Before I investigate further, I though I would ask to see if anyone has had this problem.
I have searched this forum but came up with a blank, so please redirect me if you can.
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #705597 28th Nov 2024 3:09am
Marcus76
2006 Range Rover HSE 4.4 V8 Alaska White
Hello,
Maybe it is the switch under the bonnet?
Had this half a year ago.
Marcus
Post #705603 28th Nov 2024 7:58am
bigbo
Thanks Marcus I will check that.
But I didn't know that switch was connected to anything but the alarm, I do not get a "Bonnet open" message either.
Going out in the car today it would not lower on the drive, but the fault cleared itself on the way to the pub.
So it looks like I have an intermittent fault to find.
MG TF 2003
Post #705668 28th Nov 2024 7:43pm
bigbo
Checked the bonnet switch today and can confirm that it does not inhibit raising or lowering of the suspension and neither does the tailgate.
So at the moment all is well.
MG TF 2003
Post #705719 29th Nov 2024 5:35pm
tspd
Mine did this for the first time last week. All doors were closed as it beeped and flashed when locking.
Turned it on and off - fixed.
Cold weather? L322 2007 S/C 4.2L
First Full Fat!
Owner number 6
133k miles and counting
Buckingham Blue
Previous cars
'09 VW Fox
'15 VW Beetle GTI
'19 First Edition Velar
'22 XC90 II
'24 L322
Post #705881 1st Dec 2024 11:26pm
tb10
England 2005 Range Rover Vogue 4.4 V8 Tonga Green
When I had my first FFRR the suspension did not work but I diagnosed (without a code reader) that the courtesy lights did not activate when I used the passenger rear door. I replaced the door lock mechanism and everything then worked. Is it possible that you have a faulty microswitch in one of the door locks?
regards
John
Post #705883 2nd Dec 2024 1:15am
