Home > My Range Rover > LPG Supercharged Update |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
Hi Phil, Well I've just got it back, and all of the problems appear to be solved. It is now running perfectly on LPG, with NO noticeable loss of power, hesitation or anything. No warning lights, no problems. Time will tell I guess, but from what I think BigJ is totally right. The Denso Ecu doesn't communicate well with some kits. It does with the BRC kit. Also you need two reducers which can deal with 400 bhp, which I now have. So you say you had problems, but did you suffer Valve Seat Recession? I'm assuming not. Also the fact that you broke even on the conversion is interesting. My conversion hardly cost me anything (dealer paid most) so I've probably already broken even, it's so far saved me around £800 on 5,000 miles. LPG filling stations haven't been an issue either, I fill up regularly at the same station for under 70ppl. Also what's the problem with switchover? If I run out I use petrol for a while, no problem, great range! I'm sure I'll get a 4.4 TDV8 when the time is right, until then I'm delighted with my LPG's S/C! Range Rover-less at the moment - Pining! |
18th Jun 2011 10:36pm |
I didn't realise you had suffered VSR Phil, so did you break even despite this additional cost? I guess it was around £2.5k to replace the heads? I agree about the injector systems, I don't doubt the reports of problems with early conversions, but it seems to me that a lot of the problems were for specific reasons, and there is much better knowledge about the engine, and much better higher performing kit available now than there has ever been. I may of course be wrong, but am I stupid in thinking that if it all goes Pete Tong, I can just hand over £2.5k for the hardened heads, and then be fine? Range Rover-less at the moment - Pining! |
19th Jun 2011 8:09am |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 787 |
I spent just over £5k all in on the conversion and heads which from recollection is about what I saved in fuel costs over 36k miles.
In theory yes. But mine still had issues after the head job. |
19th Jun 2011 12:12pm |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 |
Bozmandb9
23rd Jun 2011 1:15pm |
Guys,
29th Jun 2011 12:48pm |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
Much improved, helps you sleep at night |
29th Jun 2011 2:56pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35412 |
looks like you have all the hard work for anyone else that wants to lpg a s/c... |
29th Jun 2011 3:00pm |
Exactly! There's a very cheap S/C on Fleabay! Only £17k, converted all in for under £20k! Motoring heaven! Range Rover-less at the moment - Pining! |
29th Jun 2011 3:50pm |
Ludzy Member Since: 27 Oct 2010 Location: Leicester Posts: 191 |
bozmandb9 please dont post anymore updates about your sc on lpg, your gonna cost me some money at this rate
30th Jun 2011 8:32pm |
