Home > My Range Rover > LPG Supercharged Update
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
Phil. wrote:
bozmandb9 wrote:
I said, does anybody actually know of a car with a head that has failed due to an LPG conversion? and I'm not talking friend of a friend who read about it on the internet!
Mine did. I told you in an earlier post on here when you bought yours and told you about the high power issues plus plenty of others. Mine spent half its life at JE trying to sort all the 'niggles'.
Here's a challenge for you. When you decide to sell please tell us (1) if you broke even financially and (2) if you would do it again with a S/C, honestly.
At the end of the day its a personal choice. I did it and learned a lot but let's not kid ourselves about the issues and compromises involved with converting and running a S/C on LPG.
Hi Phil,
Well I've just got it back, and all of the problems appear to be solved. It is now running perfectly on LPG, with NO noticeable loss of power, hesitation or anything. No warning lights, no problems. Time will tell I guess, but from what I think BigJ is totally right. The Denso Ecu doesn't communicate well with some kits. It does with the BRC kit. Also you need two reducers which can deal with 400 bhp, which I now have.
So you say you had problems, but did you suffer Valve Seat Recession? I'm assuming not. Also the fact that you broke even on the conversion is interesting. My conversion hardly cost me anything (dealer paid most) so I've probably already broken even, it's so far saved me around £800 on 5,000 miles. LPG filling stations haven't been an issue either, I fill up regularly at the same station for under 70ppl. Also what's the problem with switchover? If I run out I use petrol for a while, no problem, great range!
I'm sure I'll get a 4.4 TDV8 when the time is right, until then I'm delighted with my LPG's S/C! 2012 SDV8 Vogue SE
Post #69203 18th Jun 2011 11:36pm
Phil.
Yes, mine did suffer Valve Seat Recession and they were replaced by JE. The VSR issue came about after a period of smooth running and then problems began to reoccur which were diagnosed as VSR after about 20k miles of LPG and 40k miles in total mileage.
Great news that all your problems are sorted. The injector systems seem to have developed significantly over the past couple of years.
Post #69208 19th Jun 2011 8:47am
bozmandb9
I didn't realise you had suffered VSR Phil, so did you break even despite this additional cost? I guess it was around £2.5k to replace the heads?
I agree about the injector systems, I don't doubt the reports of problems with early conversions, but it seems to me that a lot of the problems were for specific reasons, and there is much better knowledge about the engine, and much better higher performing kit available now than there has ever been.
I may of course be wrong, but am I stupid in thinking that if it all goes Pete Tong, I can just hand over £2.5k for the hardened heads, and then be fine? 2012 SDV8 Vogue SE
Post #69209 19th Jun 2011 9:09am
Phil.
I spent just over £5k all in on the conversion and heads which from recollection is about what I saved in fuel costs over 36k miles.
In theory yes. But mine still had issues after the head job.
Post #69239 19th Jun 2011 1:12pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Bozmandb9
Glad to hear that you have got it back and running OK - do you know if they connected the fuel trim monitoring wires onto the OBD socket ?
I think that's where my apparent temperature gauge issues are coming from - In a similar way to other people that have experienced HDC failure through the OBD wiring causing interference...
I've disconnected mine and it was OK this morning - need to investigate further.....
Cheers
Colin Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #69756 23rd Jun 2011 2:15pm
bozmandb9
BRC Installation Update
Guys,
I've now had the car back for a couple of weeks since the Lovato kit was ripped out and replaced with a BRC kit. This was all done at the installers expense, now time to review it.
Firstly, just to summarise I had found the Lovato kit to be fine. It worked well, switched over easily, pretty much what I expected, the problem was the engine management light, although it appeared to be fuelling properly, it was throwing up a fault for lean running.
So now onto the BRC kit, the kit installed was their plug and drive kit for more powerful cars, with two Genius Max reducers, each capable of handling 240 kw, it also has ugraded injectors capable of more throughput, overall the setup is easily capable of handling well in excess of the 400 bhp put out by the Supercharged. Tech information can be found here:
http://www.brc.it/public/TA01Z043I_P&D_EN.pdf
So the effect of the new installation? On LPG it's a new car. It actually feels quicker on LPG than petrol! No warning lights, no problems. Obviously the installer wish they had tried the BRC kit first, but they've learned, and now only install BRC on L322 S/C's. The installation is also more expensive than the original one, but really worth it.
To answer the other obvious question before it comes up, is it fitted with flashlube? Well yes and no. The flashlube manual kit won't work with forced induction, and the electronic kit has a dodgy reputation for reliability, so they fitted a BRC valve lubrication kit, more expensive at £245 parts only, however again worth it. Maintains a full warranty from BRC, works well with the BRC installation, and more reliable.
So now I really feel I have the best of both worlds. I can drive the Supercharged to it's limits, on LPG, with NO discernible difference in performance compared to petrol, I can run for 250 miles on a tank of LPG costing £50, or I can on a long journey use petrol and LPG and get a range of 600 miles.
I would say for anybody interested in a conversion, yes they can go wrong, but go to an installer who's just done a couple with 100% success (my installer did another one with the BRC kit recently), get the same technician, and the risk to me is more than worth it. I am now saving equivalent to £2500+ per year, I don't believe I will get Valve Seat Recession problems, but if I did, one years savings would pay for cost and installation of the JE hardened heads.
I'm happy to recommend EuroLPG, who did my installation, yes things didn't go perfectly, but they took full responsibility, and carried on improving it until I was happy, not many businesses do that nowadays, and they lost money on my conversion (quite a lot), but now they know how to get it 100% right first time.
Also they will become a site sponsor if they get another conversion which references the site. They'll charge around £2,500 for the Supercharged conversion with the BRC kit as per above.
I have no affiliation other than as a happy customer, and I know a lot of people have been interested in this subject, so thought it would be useful to share my experience. 2012 SDV8 Vogue SE
Post #70477 29th Jun 2011 1:48pm
T24RES
Much improved, helps you sleep at night Thumbs Up
Post #70514 29th Jun 2011 3:56pm
looks like you have all the hard work for anyone else that wants to lpg a s/c...
Post #70517 29th Jun 2011 4:00pm
bozmandb9
Exactly! There's a very cheap S/C on Fleabay! Only £17k, converted all in for under £20k! Motoring heaven! 2012 SDV8 Vogue SE
Post #70533 29th Jun 2011 4:50pm
Ludzy
United Kingdom 2005 Range Rover Vogue SE Supercharged Zambezi Silver
bozmandb9 please dont post anymore updates about your sc on lpg, your gonna cost me some money at this rate Shocked
seriously tho really pleased for ya that its sorted. i think i'll wait tho and see how yours pan out over the year. i do really like the idea of a sc running on lpg. dont really do many miles but planning on keeping the car until its dead so the savings for me over the life of the car could be massive.
keep us informed with regular updates.
cheers Ex FFRR 4.2 Supercharged
www.thecarpetfitter.co.uk
Post #70737 30th Jun 2011 9:32pm
