Home > My Range Rover > LPG Supercharged Update |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
Well three months on, and I'm still loving the S/C on LPG, but still having some issues. It seems that the kit I've had fitted just can't deal with the S/C under full power, and this is something I want to get right.
14th Jun 2011 9:08pm |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 |
My car has the Emer kit fitted - it has the ECU that monitors the petrol ECU's fuel trims and makes minor adjustments as necessary - it seems to handle the power OK and hasn't brought any management lights on yet (fingers crossed)
14th Jun 2011 10:26pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7944 |
May not be what you want to hear but you should read this
15th Jun 2011 7:54pm |
No worries, seen it all before. There seem to be a lot of cars with these engines running around on LPG without the benefit of the £1,400 (plus £1k fitting), hardened heads from JE! I'm sure they sell a few though. But there are now so many Range Rovers, Range Rover Sport, Jaguar XKR's etc all running on the same engine, LPG converted, and personally I've never read a direct report from anybody who has suffered valve seat recession. Plenty of problems with fuel trim, however i think mostly down to systems unable to deal with 400 bhp, as my Lovato system. I'm looking forward to getting it back with a BRC system with much better condensors and injectors, well able to deal with the power! Range Rover-less at the moment - Pining! |
15th Jun 2011 10:47pm |
Sure, as i said, I don't doubt their best intentions as I said, but has anybody got direct experience of engine trouble as a result of valve seat recession? There are many converted AJV8 engines out there without the JE heads! Range Rover-less at the moment - Pining! |
16th Jun 2011 12:13pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2571 |
Do you use Flashlube or similar?
16th Jun 2011 12:24pm |
Yes, flashlube, and yes, JE say it's not enough. But again, with quite a few converted cars around it would be interesting to get some real stats on how many have suffered damage as a result of VSR, with or without flashlube. My suspicion is that early conversions were just not well done when convertors didn't know the engine well, and now they are doing the conversions much better with better knowledge of the engine. I may be wrong though, in which case I'll end up with a knackered engine! Range Rover-less at the moment - Pining! |
16th Jun 2011 2:52pm |
Sorry to be negative but it does sound like the problems you and others are having (and where warned would have) are not worth the saving in fuel based on the up front cost of conversion and the worry/hassle of getting it to work perfectly (As SC should) with the knowledge in the back of your mind that the head may just fail at any time...
16th Jun 2011 2:57pm |
Polux Member Since: 02 Jun 2009 Location: UK Posts: 242 |
i have no idea what all the fuss is about with sc, my installer autotech installs about 5x sc every week with the prins vsi lpg system and gets no issues, well the only issue is getting the dam supercharger (dam fiddly) out of the enegine bay to fit the system.
17th Jun 2011 10:13am |
Gary, as I said, does anybody actually know of a car with a head that has failed due to an LPG conversion? and I'm not talking friend of a friend who read about it on the internet! I'm quite happy with mine, to be honest it would have been fine as it was, but I wanted to be able to use the full 400bhp on gas, so I'm delighted that the installation is being upgraded at no cost to me. As for S/Cs working perfectly without LPG, does this really describe any RR? I would say mine with LPG works at least as well as most, as we know, we may love our RR's, but to expect them to work perfectly all the time seems to be too much to ask even brand new from the showroom! Range Rover-less at the moment - Pining! |
17th Jun 2011 11:14am |
Its a personal choice but as a dealer I would never recommend an SC conversion to a client whereas I would be comfortable recommending V8 conversion.
17th Jun 2011 11:43am |
BigJ Member Since: 16 Mar 2011 Location: North Yorkshire Posts: 247 |
The problem with the supercharged engine is the poxy Denso (Read Japanese) ecu. Which causes problems.
17th Jun 2011 12:56pm |
Thanks BigJ, that's great news since I have a new BRC kit going on right now! Range Rover-less at the moment - Pining! |
17th Jun 2011 1:06pm |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 786 |
Mine did. I told you in an earlier post on here when you bought yours and told you about the high power issues plus plenty of others. Mine spent half its life at JE trying to sort all the 'niggles'. I wouldn't do it again even if all the 'niggles' were sorted (and you can't sort the low fuel emergency swap over niggle) because its such a pain having to find a LPG station and fill up every 200ish miles. I did have a sat nav with LPG stations listed but you often pull off your route only to find the station no longer has LPG. A lot of the branded stations are removing LPG because they are not turning over enough volume to make money. I did 36k miles in less than 18 months so often filling up 3 times a day [e.g. 2 x 200 miles and then need it full for the next day] that's at least 30mins wasted time a day compared with a full tank of diesel. If you're not doing those sort of miles then it will take forever to pay for itself and makes the whole reason for doing it in the first place void. I broke even on mine financially before I got rid and should have spent the LPG saving on petrol and enjoyed it far more than I did. Now I have a TDV8 and the day-to-day performance isn't much different to the S/C, long run mpg is about 30% better than my S/C and the performance could be improved with a £300 re-map if I was inclined. Here's a challenge for you. When you decide to sell please tell us (1) if you broke even financially and (2) if you would do it again with a S/C, honestly. At the end of the day its a personal choice. I did it and learned a lot but let's not kid ourselves about the issues and compromises involved with converting and running a S/C on LPG. |
18th Jun 2011 6:13pm |
