![]() | Home > Maintenance & Mods (L405) > Help - Suspension fault Green & Yellow |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8543 ![]() ![]() ![]() |
That's a shame, you'll probably be doing this then....
bigdave Site Sponsor Member Since: 27 Jun 2011 Location: Cornwall Posts: 222 ![]() ![]() ![]() |
Thanks Pete,
Don't be tempted to run it with a leak, if the pump runs dry you will have an even bigger bill... |
Yeah the chaps said that.
Oh god dont say that!! All things transport - big or small, UK or planetwide.
My front pipe went first, the rear started leaking as I brushed past it....?
Great!!
If you have the four way climate then get the rear pipes checked as they rot as well and run under the rear subframe, be a small amount to replace them if you are doing the lot....
Yes indeed i do.
May as well, mine were all done a couple of years ago so still good... Pete
Struggling to find the pipes to be honest.
Depends where yours have leaked, mine were fine going into the manifold, they rusted through near the wheel arch...
Thanks Pete,
I may have found the parts i need in Vancouver.
