Home > Maintenance & Mods (L322) > Draining Old Petrol from a 2006 SC |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8246 |
Pretty sure the pump is in the tank on the S/C, get under the rear seat, identify the feed pipe with the aid of the W/M which you can download from the WIKI above, remove the pipe, add a long pipe to the fitting and into a can, turn the ignition on and pump it out.... Pete
15th Nov 2024 4:40pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1371 |
Is the fuel filter not under rear section of the LHS sill ? Might be able to disconnect it and with pump out or suck it out from there. V8 or else ... |
16th Nov 2024 8:33pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 901 |
If its just 1/4 tank put in some fuel conditioner a few gallons of super-duper premium and run it. Or crack off the hp fuel line in the engine bay connect it to rubber hose into a container turn on the ignition and let it pump out.
16th Nov 2024 11:32pm |
Andy H Member Since: 30 Jul 2022 Location: FL Posts: 2 |
Thanks for the replies. I ended up removing the caps on each side of the tank and siphoning the petrol out of both sides of the tank. Added 10 gallons of fuel and some Techron and it started right up. |
28th Nov 2024 5:13pm |
