Home > Technical (L405) > Reccomend recon engine 2017MY RR Autobiography SDV8?
Page 2 of 4 <1234>
Chef45
Yeah, I wouldn't want the V6, it's underpowered. I guess I was thinking more of the V8 supercharged petrol but I guess that's tons of work given it's a diesel.
Sounds like I have to decide between QP, a breaker engine but only if I can get the number, or scrapping... No idea what to do. It's unbelievable really that a £150,000 V8 diesel car with 55k miles is potentially almost worthless.
Post #704415 14th Nov 2024 10:35am
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
Chef45 wrote:
So sorry to hear that, No, it's 2017, so out of warranty. I love it and have looked after it well - did a 3 stage paint correction myself. If you can't get a reliable engine though, maybe I'm better of scrapping Big Cry
It's a horrible position to be in, when I looked at recons the warranty was 12 months of 10K miles, seeing as I do 30K + a year that just made me think it wasn't worth it. I was lucky to an extent as even though my crank was too damaged to regrind everything else was ok. I know someone who has a SDV8 that the same happended too and the debris in the oil from the failed bearing also trashed both the cylinder heads cam journals and both turbos, that's still sitting in his workshop 12 months on as he doesn't know where to go with it. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #704416 14th Nov 2024 10:36am
Chef45
Wow. I had no idea these issues were so common! I really thought the engine was bulletproof - I've always been concerned about suspension. Little did I know.
I also don't know the extent of the damage but most of the replacements seem to come with turbos. No idea what I'd get as a non-runner but given it won't be much, I'd more or less decided to put a new engine in it and run it forever. BUT only if I can get an engine I can trust - not going to do this twice. As I have a new car now, it'll just be a run around.
Post #704418 14th Nov 2024 10:39am
4RRS
Same here, I went with the SDV8 as back then they had a brilliant reputation, it seems more lately there are quite a few failures being reported, but on the whole it is a good engine. I never got to what caused mine to fail and everything was checked. I can only hypothesise that in it's earlier life it suffered oil dilution and that started the ball rolling towards total failure.
Non runner prices are ridiculous as people in the trade know the position you're in. I decided to repair mine myself as it's now a known quantity and I can only hope that seeing as I did everything exactly to the book using all genuine parts it will last me a good while. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #704419 14th Nov 2024 10:49am
Chef45
Thanks for your advice. Right now, I'm leaning towards a breaker if they can supply an engine number and history. Somehow it feels less risky than a badly reconditioned one. Dunno what I'd get as a non runner but let's say £10k - it's worth more than that to me as a weekend car, so can't see the point in selling it - it's got more than £10k's worth of leather!!
Post #704420 14th Nov 2024 10:55am
4RRS
Depending upon spec & whether it's a facelift 2017 model or pre-facelift model I'd say if you got £10K you would be doing very, very well. I've seen 2016 models go for £6K.
I'd agree with the breaker route, at least (hopefully) it hasn't been messed with, that was my route but failed trying to get any assurances of mileage & history and hence went with plan B. From what I recall most breaker units were around the £7-9K range, In my mind I'd beware of any who want your old engine in exchange as that in itself tells you they are rebuilding them. Ideally you want an engine out of an accident damged car that can be proven to be out of that vehicle, not one they've just bodged together and are trying to sell as out of a breaker. It really is a minefield. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #704422 14th Nov 2024 11:14am
GraemeS
To use an engine from a breaker, you really need to have the sump removed to check that the crankshaft journals are in good condition but if a journal is damaged then to be able to reject/return the engine. Once confirmed that the journals are OK then replace the mains and big-ends then change the oil regularly.
Post #704423 14th Nov 2024 11:16am
Chef45
Thanks so much GraemeS. I'm a bit out of my depth. What would you do, in my position?
Post #704424 14th Nov 2024 11:17am
4RRS
Totally agree with GraemeS, just try getting them to agree to that though!! L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #704425 14th Nov 2024 11:17am
cass
Have you thought about cutting out the breaker and looking for a complete write off then recovering what you can selling the bits you don’t need?
Post #704435 14th Nov 2024 2:43pm
4RRS
I think that was the route Cam tech Craig took and all ended well for him. Obviously if you've got to pay someone to do it, there's a fair few hours in labour involved.
Supply of breaker engines are not that plentiful as the 448DT was only ever used in the 405 and 494 so there's not that many options, unlike the SDV6 where you can go with the LR offerings or a Jag Xe/XF and a sump change etc. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #704436 14th Nov 2024 3:02pm
cass
I recalled that someone had done that.
Unfortunately I think that you’re right about the labour cost. It pretty much makes any repair unviable unless there’s some DIY involved.
Will the 4.4 from the L322 not fit?
Post #704441 14th Nov 2024 3:27pm
4RRS
It's effectively the same engine in the L322, as much as the block, crank and pistons go. I'm not sure about heads and cams as the engine was only Euro 4 emissions so there wil be emmission related differences and possibly cam profiles will come into that also. Certainly as a short block replacement you could use the L322 as a donor. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #704445 14th Nov 2024 4:04pm
kevinp
Excuse me if I'm completly going in the wrong direction here, but there seems to be lots of crankshafts for sale online, some just for the crankshaft, some with all the pistons, shells, gaskets etc, some upgraded crankshafts.
Ignore this if it is not what you are looking for. Embarassed
Post #704453 14th Nov 2024 5:30pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Try keeping an eye on this few
https://www.copart.co.uk/lot/64949694/clea...-rove-york
https://www.copart.co.uk/lot/70939384/clea...verhampton
https://www.copart.co.uk/lot/68785734/clea...er-sp-york
Post #704455 14th Nov 2024 5:39pm
Page 2 of 4 <1234>
