Home > Technical (L405) > Reccomend recon engine 2017MY RR Autobiography SDV8? |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 207 |
Been there, done that. My conclusion was there was no reliable reconditioned units, so I ended up buying a secondhand short block just for the crank and then rebuilt mine. If you want the info, take a look at: -
13th Nov 2024 4:13pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1189 |
I keep recommending QP-Online Based in Maidstone. 2017 SDV8 4.4 silicon silver AB
13th Nov 2024 4:33pm |
Qp were top of my list before I decided to go my own route. Biggest issue is the crank, if it can't be ground then its aftermarket only and I wasn't prepared to take the risk on an essential component like the crank. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
13th Nov 2024 4:43pm |
Chef45 Member Since: 02 Jan 2024 Location: Hampshire Posts: 14 |
Oh dear.... that doesn't bode well. Surely there is at least one good company? I found turner engineering but they don't do this engine.
13th Nov 2024 4:52pm |
I considered that, but how do you know what you are buying, I guess a breaker engine and a strip down to check bearing shells could be a possible route. In the post I linked to I mentioned I rang many breakers and the general concensus was they're all liars, trying to tell me an engine was a 2017, when it had early (2013-14) intake stub hoses. Asked many for engine numbers or vin of car to verify it's year and was never met with a response.
13th Nov 2024 5:01pm |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1419 |
What happened? The V8 diesels are usually pretty robust 2021 D350 Fifty Edition - Carpathian Grey 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
13th Nov 2024 5:59pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1382 |
That was what I thought too, but at the dealer last month I was told there were now increasingly crank problems, which, combined with the lack of replacements, had led them to adopt a policy of not having them as second hand stock any more. Only Range Rovers since 1988 |
13th Nov 2024 8:35pm |
The reason being, if they sell one as approved used and it suffers an engine failure within the warranty period, JLR have to buy back at the sale price as they can't repair them.
13th Nov 2024 8:44pm |
Thanks! |
14th Nov 2024 10:01am |
I was just driving along and it got lumpier and lumpier until it was lurching and screeching and sounded like a bag of spanners. Got AA and to garage - DOA big end!! |
14th Nov 2024 10:02am |
WOW!!!!!!!!!!!! This is OUTRAGEOUS. Is there a different engine that would easily fit that's better? |
14th Nov 2024 10:04am |
Yep, same here, big end on cylinder 3 when mine died. I take it you don't have LR warranty? L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
14th Nov 2024 10:27am |
So sorry to hear that, No, it's 2017, so out of warranty. I love it and have looked after it well - did a 3 stage paint correction myself. If you can't get a reliable engine though, maybe I'm better of scrapping |
14th Nov 2024 10:29am |
To my knowledge no, too many differences to even think about a 3L SDV6 and then they're known to snap cranks so no real advantage, plus you'd never be able to sell it or probably even register the change with DVSA as the type approval would be invalid. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
14th Nov 2024 10:30am |
