![]() | Home > In Car Electronics (L405) > DIY Apple CarPlay install L405 |
E500 Member Since: 10 Sep 2024 Location: Hertfordshire Posts: 85 ![]() ![]() |
I bought an L405 a few weeks ago and wanted to add CarPlay to it.
Then remove the torx screws for the metal surround (careful it's sharp), remove that, and remove the control panels on each side - these just clip in - unplug them and put them out of the way. Pop off the silver 'grab handles' either side of the climate unit - these should just pull directly backwards without much force - then pull off the trim panel around the climate unit; again it should just unclip without much fuss. And remove the climate unit.
Now both units can sit out and give you access to the cables.
The hardest part was actually fitting everything back into the dash. What seemed to work well for me was to connect everything up and then tuck the unit right at the top of the dash, behind the OEM screen. I had seen people try to put it behind the climate unit but I couldn't make that fit. You could also put the unit under the glovebox and route the cables into the dash that way... I did this for my USB cable and my wifi antenna, like so, by dropping the glovebox down and feeding the cables through and into the dash.
Assembly is the reverse but check everything works before you button it all up.
And I still have my OEM stuff when I want it.
This unit works by hijacking the OEM nav function. So you do lose that... Oddly I have also lost my 4x4i screen, and my wade sensor! This doesn't really bother me but be aware. Other than those issues it works really well. It will connect to the phone using wifi so no need to have it plugged in, and the connection is fast when getting into the car. I was worried about GPS signal, as using Google maps on my phone in a phone mount didn't work well with the car's UV windscreen and sunroof etc. However it seems to use the car's GPS for CarPlay as the location is always spot on. Hope that's useful for someone. |
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 ![]() ![]() ![]() |
Top job, thanks for sharing this. Many thanks
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1446 ![]() ![]() |
I'd love to know your longer term thoughts on this as I'm like the OP, I quite like the original look / feel of the units, but the lack of upto nav is beginning to show its issues on journeys.
PhillV8s Member Since: 03 Jun 2022 Location: Worcestershire Posts: 45 ![]() ![]() ![]() |
You can have DAB from the OEM system whilst having say Waze on the screen as you just change the Audio setting from AUX to DAB etc but keep the CarPlay screen open. 2013 SDV8 4.4 Vogue SE Aintree |
I’ve done a bit of a hacky solution for Bluetooth audio. I haven’t used the aux input method at all, I just have my phone paired with the car’s Bluetooth and use that (because I never have instructions on google maps or whatever I don’t care about ‘proper’ CarPlay audio). I think the steering wheel controls still work OK but I don’t think I’ve tried Spotify actually. Will try this evening and let you know. The CarPlay unit I fitted has a configuration option in the setting screen to ‘use car’s Bluetooth’, which I think means in theory I could use that for the CarPlay audio… But as it’s not a priority for me I haven’t played around with it to see what works. |
Update!
Jef Benitez Member Since: 24 Jul 2018 Location: Warwickshire Posts: 4 ![]() ![]() ![]() |
I found that the unit fits quite nicely under the piping for the dash vents, just above the screen (can see the silver unit in the photo) I bought the same unit as OP, doesn't seem to have the "use car bluetooth" option in the settings that I can see although works well otherwise (just dont have the skip button working on spotify, all ok otherwise) |
twintorque Member Since: 27 Mar 2023 Location: Glasgow Posts: 6 ![]() ![]() ![]() |
I presume that you also lose the indash junction displays at junctions as it’s not the OEM satnav ?
Sorry my car’s been away for a while for some work so hadn’t had chance to drive it.
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 485 ![]() ![]() ![]() |
how is the the sat nav any issues with google maps ? .does it use the range rovers own gps ariel ?
Yeah seems to use the car’s GPS as it’s spot on. I only used my phone in the car for google maps once, driving it home from collecting it, and the location was all over the place. So I fitted the CarPlay the next day |
think i will be getting one of these soon |
have you used the wifi aerial ? |
Yes that’s the thing I routed into the back of the glovebox. I don’t ever connect my phone to it by a cable, just connects automatically when I get into the car.
