Home > Technical (L322) > L322 Rear sub frame bush replacement info
Page 4 of 4 <1234
BAZ8046
Have just done this today and it is relatively straightforward.
Mine is a 2012 and has the rivets which I will replace.
They seem like a tight fit but it is possible for the subframe to move up and down on the bush.
I used the Meyle HD bushes which fit fine.
As has been said before a 24mm ratchet spanner is a big help.
The only tip I have to add is that if the bushes are stiff coming out rather than stress the tool just apply some heat to the bush housing and this helps reduce the friction.
Glad I did mine as they were starting to debond from the metal core.
 2012 TDV8 4.4 Westminster Santorini black
2016 Discovery 4 Landmark
2002 Defender TD5
Post #703618 2nd Nov 2024 6:51pm
Page 4 of 4 <1234
