Home > Technical (L322) > Battery and gearbox |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7801 |
I don’t believe so. The earlier ZF gearboxes are not known for their longevity in these heavy motors, though they are better than the GM box in the TD6.
26th Oct 2024 6:36pm |
Philcaz Member Since: 18 Apr 2020 Location: London Posts: 14 |
Thanks for the reply |
26th Oct 2024 6:55pm |
I’m sure others will be along with a more useful answer….
26th Oct 2024 7:21pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 968 |
A weak battery/low voltage can certainly cause issues with the ECUs e.g. TRANS. FAILSAFE PROG messages, etc. but I doubt it would cause a transmission judder. The most common cause of this with the 5HP24 is wear of the torque converter lock-up clutch friction plate. A fluid change, or friction modifiers added to the fluid, can produce a temporary improvement but ultimately the converter will require replacing/remanufacturing.
26th Oct 2024 10:26pm |
Thanks for that Phil |
27th Oct 2024 9:35am |
