Home > Technical (L322) > Subtle footwell vibration. |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 799 |
Is it across the rev range and at all speeds when you put the engine / drive train under heavy load? |
28th Dec 2022 7:53am |
lodelanelad Member Since: 14 Dec 2021 Location: London Posts: 51 |
Start with the easy stuff - are all wheels balanced and is tracking aligned? If so then I would try:
28th Dec 2022 8:33am |
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 414 |
It is across the rev range yes.
28th Dec 2022 10:44am |
The juddering of a failing torque converter is caused by the lock up clutch misbehaving when in "continuous slip" mode. If you have the car in sport/manual mode the lock up clutch is locked solid. |
28th Dec 2022 11:09am |
Thanks clarifying. Will give it a go. 2009 pre-facelift 3.6 TDV8. |
28th Dec 2022 11:48am |
Gearbox works well and just had all the oils changed.
8th Feb 2023 5:19pm |
Noticed in the service history that the fuel filter and air filter had not been changed in 3 years. Sorting these two things out has basically solved the bulk of the issue, there is still a slight vibration under load but guessing within normal-ish tolerances.
7th Mar 2023 10:57pm |
Pal Member Since: 06 Jan 2020 Location: Budapest Posts: 26 |
I face the same vibration issue and hav thought of engine mou ts too…have you replaced yours, has it cure the problem? |
22nd Oct 2024 9:46pm |
I have had so much other stuff go wrong on the car I forgot about this!
23rd Oct 2024 9:56am |
