![]() | Home > Technical (L322) > Subtle footwell vibration. |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 814 ![]() ![]() |
Is it across the rev range and at all speeds when you put the engine / drive train under heavy load? |
lodelanelad Member Since: 14 Dec 2021 Location: London Posts: 57 ![]() ![]() ![]() |
Start with the easy stuff - are all wheels balanced and is tracking aligned? If so then I would try:
KitTheRam Member Since: 29 Mar 2022 Location: Essex/Herts Border (originally from Derby) Posts: 433 ![]() ![]() ![]() |
It is across the rev range yes.
The juddering of a failing torque converter is caused by the lock up clutch misbehaving when in "continuous slip" mode. If you have the car in sport/manual mode the lock up clutch is locked solid. |
Thanks clarifying. Will give it a go. 2009 pre-facelift 3.6 TDV8. |
Gearbox works well and just had all the oils changed.
Noticed in the service history that the fuel filter and air filter had not been changed in 3 years. Sorting these two things out has basically solved the bulk of the issue, there is still a slight vibration under load but guessing within normal-ish tolerances.
Pal Member Since: 06 Jan 2020 Location: Budapest Posts: 26 ![]() ![]() ![]() |
I face the same vibration issue and hav thought of engine mou ts too…have you replaced yours, has it cure the problem? |
I have had so much other stuff go wrong on the car I forgot about this!
