![]() | Home > Technical (L322) > Engine System Fail with fast acceleration |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7976 ![]() ![]() ![]() |
Maybe some clues on this thread - https://www.fullfatrr.com/forum/topic60733.html
L322_TDV8 Member Since: 22 Oct 2024 Location: Warwickshire Posts: 3 ![]() ![]() ![]() |
Thank you, I'll check that out. I had a fault report one, these are the codes.
You can try putting each of the fault codes into the search and see if anything comes up.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3156 ![]() ![]() ![]() |
It sounds like it was the waste gate actuator that the mechanic freed off.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35525 ![]() ![]() |
split intercooler hoses? ... - .- -.
RobErica Member Since: 16 Nov 2023 Location: Loosbroek Posts: 38 ![]() ![]() |
And check for oil in the intercooler pipes |
Good shout - I'll take it back to the mechanic and check on the actuator. It would make sense if it was stuck again. They did a quick job with lubricant spray and it could have easily ceased up after a few days. It made a huge difference when it was free. While i'm there, I'll get the hoses checked too.
