Home > Technical (L322) > left/ride play in rear left wheel |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 394 |
jic i tightened the toe rod part that connects to the hub while the car was on the ground.
21st Oct 2024 10:16am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2436 |
The nut on the parallel shaft on the ball-joint can be tightened with the suspension at any angle due to the joint being a ball-joint, but not for the inner bush bolt where the wheel needs normal weight on it during alignment.
21st Oct 2024 10:29am |
the inner bush is perfectly tight.
21st Oct 2024 10:31am |
right so i lifted the car, checked the play again.
21st Oct 2024 2:20pm |
