Home > Technical (L405) > CTEK battery trickle charger/ conditioner
firstrr
England 2019 Range Rover Autobiography SDV6 Santorini Black
Anyone know, is it ok to connect the CTEK battery trickle charger/conditioner to the remote battery connectors under the bonnet? The manual states to remove the battery from the vehicle to charge it but most do say that but all will sell you a trickle charger for when vehicle is going to be idle for a couple of weeks.
Post #702507 18th Oct 2024 8:17pm
Can't see why not...?? But I connect mine through the towing electrics with an adaptor they used to sell in the shop on here but that seems to be broken at the moment. Mike - MPx
Post #702515 18th Oct 2024 8:57pm
Nabbler
Wales
Re: CTEK battery trickle charger/ conditioner
That’s exactly what I do, I generally pop mine on once a week as I don’t do a lot of mileage and it gives you the opportunity to have a peak at water ect. I used the crocodile clips originally but now use the ringlet option held down by a couple of rubber gromits 2025 SV P615
2021 SVautobiography Dynamic Black ( gone )
1997 C140 Mercedes Benz CL500
Post #702521 18th Oct 2024 9:17pm
firstrr
Thanks guys. Just wanted to make sure it wouldn’t mess with any of the electronic ‘giblets’ that may hide en route to the battery in the boot.
Post #702522 18th Oct 2024 9:26pm
Nabbler
Wales
I’d hold fire till one of the boffins confirms this to be ok, I’ve been doing it since July with no adversities to report but my wife thinks I’m a numpty so as said confirmation will be peace of mind for both of us 2025 SV P615
Post #702523 18th Oct 2024 9:33pm
firstrr
Good point, hope for input from a tech boffin/ expert to confirm.
Post #702526 18th Oct 2024 9:49pm
caymanblack
Mines been connected that way for the last two years and its on all the time , just fine. overfinch modified
Post #702528 18th Oct 2024 9:55pm
Nabbler
Wales
Good point, good point that’s you and the Mrs Laughing 2025 SV P615
Post #702530 18th Oct 2024 10:00pm
fisha
I've had mine hooked onto a halfords battery charger using the terminals in the engine bay for a couple of weeks recently whilst doing work on it. No issues.
I've also had it hooked up the same way for a shorter day / overnight periods too ... no issues. I normally would do it when I could tell the engine was cranking a little bit slower than normal in the colder whether.
So personally I'd say it would be fine. V8 or else ...
Post #702531 18th Oct 2024 10:02pm
Alex1976
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
If I am not using the FF for a week or so I will often plug it into the ctek using the under bonnet terminals just to keep the battery in top condition.
Post #702535 18th Oct 2024 10:17pm
Gremlin500
@firstRR,
A definitive yes, that’s fine.
I’ve had my CTEK MXS5 connected to the posts via a CTEK socket in the OS little lower grille for the past 2 years, (only when parked, obvs) and it charges/conditions the battery as expected.
[img]https://www.fullfatrr.com/gallery/albums/userpics/24757/normal_IMG_0512.jpeg[/img]
[img]https://www.fullfatrr.com/gallery/albums/userpics/24757/normal_IMG_6280~0.jpeg[/img]
[img]https://www.fullfatrr.com/gallery/albums/userpics/24757/normal_IMG_6279~0.jpeg[/img]
[img]https://www.fullfatrr.com/gallery/albums/userpics/24757/normal_IMG_6278~0.jpeg[/img] “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #702537 18th Oct 2024 11:05pm
firstrr
Thanks all for input and advice, I’ll go ahead
Post #702552 19th Oct 2024 9:37am
Wkr
United Kingdom 2014 Range Rover Vogue SE SDV8 Scotia Grey
Solar panel plugged into obd socket
My previous car RS6 sometimes sat for some time unused due to my covid problem and to save battery going flat I plugged a solar panel to the obd socket. This did the trick. Now progressed to a 2014 L405 sdv8 4.4 and intend doing the same. Cant see what harm it will do. I forgot to add that before turning on ignition unplug from obd socket.
Post #703799 5th Nov 2024 2:08pm
pcourtney
delete
Post #703800 5th Nov 2024 2:19pm
pcourtney
yes a little solar panel is fine Smile
Post #703801 5th Nov 2024 2:19pm
