![]() | Home > Technical (L405) > CTEK battery trickle charger/ conditioner |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 614 ![]() ![]() ![]() |
Can't see why not...?? But I connect mine through the towing electrics with an adaptor they used to sell in the shop on here but that seems to be broken at the moment. Mike - MPx
Nabbler Member Since: 11 Jul 2024 Location: South West Wales Posts: 125 ![]() ![]() |
That’s exactly what I do, I generally pop mine on once a week as I don’t do a lot of mileage and it gives you the opportunity to have a peak at water ect. I used the crocodile clips originally but now use the ringlet option held down by a couple of rubber gromits 2025 SV P615 2021 SVautobiography Dynamic Black ( gone ) 1997 C140 Mercedes Benz CL500 |
firstrr Member Since: 27 Sep 2024 Location: Lancashire Posts: 16 ![]() ![]() ![]() |
Thanks guys. Just wanted to make sure it wouldn’t mess with any of the electronic ‘giblets’ that may hide en route to the battery in the boot. |
I’d hold fire till one of the boffins confirms this to be ok, I’ve been doing it since July with no adversities to report but my wife thinks I’m a numpty so as said confirmation will be peace of mind for both of us 2025 SV P615
Good point, hope for input from a tech boffin/ expert to confirm. |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1163 ![]() ![]() ![]() |
Mines been connected that way for the last two years and its on all the time , just fine. overfinch modified |
Good point, good point that’s you and the Mrs ![]() 2021 SVautobiography Dynamic Black ( gone ) 1997 C140 Mercedes Benz CL500 |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1473 ![]() ![]() |
I've had mine hooked onto a halfords battery charger using the terminals in the engine bay for a couple of weeks recently whilst doing work on it. No issues.
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 169 ![]() ![]() ![]() |
If I am not using the FF for a week or so I will often plug it into the ctek using the under bonnet terminals just to keep the battery in top condition. |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1687 ![]() ![]() ![]() |
@firstRR,
Thanks all for input and advice, I’ll go ahead |
Wkr Member Since: 21 Aug 2024 Location: Aberdeenshire Posts: 8 ![]() ![]() ![]() |
My previous car RS6 sometimes sat for some time unused due to my covid problem and to save battery going flat I plugged a solar panel to the obd socket. This did the trick. Now progressed to a 2014 L405 sdv8 4.4 and intend doing the same. Cant see what harm it will do. I forgot to add that before turning on ignition unplug from obd socket. |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 905 ![]() ![]() ![]() |
delete |
yes a little solar panel is fine |
