Home > General > I didn't know, did you? |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 |
Works on a hill start too. 405 AB exec seats Baltic and Cirrus
17th Oct 2024 5:54pm |
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 674 |
That's exactly how I found out, being in the valleys full of hills. Put handbrake on a steeple hill junction, forgot I put it on as I was there a fair bit and accelerated to pull out and it moved off with no bong. So I tried the same again at some lights and thought what a result. |
17th Oct 2024 6:08pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7840 |
I like to take it off manually, just me….. the car has a feature where if you come off the foot brake it holds pressure for a bit so you can get on the throttle without rolling back. That’s separate to the hand brake, but that prob does a similar thing to. Some clever stuff going on, most of which is probably to assist off roading.
17th Oct 2024 6:30pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2536 |
Not just you who prefers to release the park brake manually.
17th Oct 2024 7:36pm |
I didn't even know it had hill hold feature either until you guys told me. I just thought it was the characteristics of it being an auto of not rolling. I have been using the auto release since I found out it can do it. Am I just being lazy not moving arm to do it myself? |
18th Oct 2024 6:47am |
I’m not keen on that little time period where you press the throttle and the handbrake is still on. I’m sure it’s fine and can also work that way, as indeed does, but I don’t like keep doing it. In the same way that when I park up, I put the handbrake on with my foot still on the brake, gearbox into N, foot off brake (weight of car settles on handbrake) then I select P. I don’t like the weight of the car hanging on the gearbox, as it were…. But then I’m a bit set in my ways 🤣. Some folks just use P and never use the handbrake, not for me….
18th Oct 2024 7:58am |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 768 |
Sorry to appear like a smart ass, but I've known this for sixteen years!
18th Oct 2024 8:44am |
That's exactly what I do too Mj, like you I always put it in neutral then handbrake on. As I park on a slight incline outside the house I'm rather sure it will do it the world of good not resting on the gearbox in park. I always put it in neutral when I'm stationary at lights etc etc too. I was told many years ago by a very old school mechanic who did classic car restorations namely jaguar E-types, to put it in neutral when you are stationary so there's no unnecessary force on the gearbox, that was his number one rule with autos. |
18th Oct 2024 8:45am |
So only now you just tell us this info JMC lol? Anything else we should know about that you know that we don't? |
18th Oct 2024 8:47am |
Orkney Grey is the best (and fastest) colour. Black interior outlasts all the others. Removable towbar isn't removable if left attached for years. 3.6 Vogue seats are the most comfortable. GAP tool is essential glovebox accessory for 4.4TDV8 Money isn't the most important thing in life. The older I get, the more I realise that people confuse wrinkles for wisdom |
18th Oct 2024 8:57am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8335 |
Please leave a list of what you don't know and we will try to help..... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
18th Oct 2024 9:26am |
We could be here all day if I did that haylands
18th Oct 2024 10:51am |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 214 |
If you have the handbrake on and the door is open it won’t automatically release. |
18th Oct 2024 2:55pm |
If you're using the brakes at the same time for any length of time then you're risking failure of the gearbox selector module. There's a 1 ohm resistor in the circuit for the rotory selector motor that is used to determine if the motor is drawing current by checking the voltage drop across the resistor. The resistor overheats if power is applied for too long, melting its solder which then stops the selector motor from working. The solder will crystilise if it almost melts then sets again which increases the resistance in the joint which causes the joint to overheat more quickly next time it starts to get hot. Neutral + brake pedal needs to be for only short periods. |
18th Oct 2024 8:01pm |
