Home > Maintenance & Mods (L405) > L405 Poor heater
rattly
L405 Poor heater
Hi all,
Bought my current Autobiography in the summer, now the weather changed i`m realising my heater is useless.
Done thousands of miles in and engine temp is fine.
Front fan control seems to work (front blower sounds a bit stifled!, rear blower sounds normal), pretty well no air flow from the vents, and my legs are always freezing!!
Only code in is for Auxiliary heater water pump- open circuit, B12A6-13
All help welcomed or i`ll re-taxing my old Sport!!
Thx in advance
Post #701920 10th Oct 2024 3:18pm
You could try cleaning this, it's the cabin temp sensor
see how to reach it in this thread, it's very easy and a free check....
https://www.fullfatrr.com/forum/topic69334.html? Pete
Post #701935 10th Oct 2024 8:30pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Does it have the fuel burning heater? If it does there’s a diverter solenoid that stops working (oem item is Bosch and about £120 if you don’t buy from dealer. Was a bit of a pain to get out but warm heater again for me. My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #701936 10th Oct 2024 8:32pm
rattly
Thx both,
Just cleaned the cab sensor and I seem to have airflow now!
Will give it a run later and see how warm it gets inside..
I’ll keep this thread updated!
Post #702067 12th Oct 2024 1:20pm
rattly
Definitely have a better blower motor now, not as good as i`d expect tbh, but still very poor heat.
I`ll try and get under it and see if have the fuel burning heater, i have a remote for a pre heater so would guess i have ??
Post #702310 16th Oct 2024 4:00pm
hoppy_70
Yes if you have the FBH remote then it’ll be fitted. It’s the left side of the engine bay right at the back. This is the solenoid I fitted (diverter valve), much warmer now! It sticks apparently stopping hot water flow through the matrix.
https://www.ebay.co.uk/itm/116225611658?mk...media=COPY My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #702317 16th Oct 2024 7:26pm
