Home > My Range Rover > Another rescued L322 - 2011 5.0 SC Autobiography……Copart |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 166 |
Looking forward to further updates on what needs to be done. |
14th Oct 2024 10:39am |
Salter121 Member Since: 20 Jun 2018 Location: Berkshire Posts: 91 |
Once I got the car delivered, it was time to investigate. Clearly, people don't sell a car like this at auction to make a profit. I knew it was likely because someone either did not have the knowledge or the budget to sort it out—my biggest concern was the engine.
16th Oct 2024 9:19am |
As you can see - missing a shroud...the gearbox oil cooler also attaches to this shroud so that was just there loose.....
16th Oct 2024 9:26am |
Power steering reservoir loose, missing the bracket and totally facing the wrong way?
16th Oct 2024 9:29am |
Left and right Oxygen sensor heat shields in the boot.....
16th Oct 2024 9:38am |
Had no idea what this was - after spending ages going through TOPIX, I found it - goes on the rear right side of the engine
16th Oct 2024 9:43am |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 220 |
Appreciate the detailed update, quite the project.
16th Oct 2024 9:57am |
Top mounting bracket front he ECU was in the boot.....initially had no idea what it was..
Had to replace a bunch of parts at the rear of the engine bay to re-house the ECU's and replace a uber of the rubber seals.... the scuttle panel willed replacing, the rubber seal is perished and it has been letting in water for a while....previous repair attempts with Tiger Seal look awful...
16th Oct 2024 10:14am |
Painstakingly, I began working through the front of the car, undoing everything that had been installed incorrectly. I used cable ties to ensure everything was secured properly, with no cables touching anything hot. I installed a new shroud, refitted the gearbox oil cooler, and addressed various other issues.
16th Oct 2024 11:28am |
