Home > My Range Rover > Another rescued L322 - 2011 5.0 SC Autobiography……Copart |
Salter121 Member Since: 20 Jun 2018 Location: Berkshire Posts: 128 |
The auction listing did not list anything wrong; but clearly it needed a lot of love…I have just been reading your amazing posts on your L322 5.0 SC project - puts my post to shame…. Some great reference points for me; thank you.
19th Oct 2024 6:30am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3097 |
Glad I could help
21st Oct 2024 8:11pm |
Gentle Giant Member Since: 01 Nov 2024 Location: East Neuk of Fife Posts: 16 |
Can't wait to see how you get on...
1st Nov 2024 12:31pm |
It’s been a while since I updated on the L322 5.0 SC…..after hitting issues I could not sort on the drive without a ramp I sent the car into Nick Kerner 4x4 to have the engine and gearbox dropped….with so many little things clearly re-installed incorrectly when they put the engine back in before it ended up at Copart, and the fact that it would not engage gears correctly and the gear box in Park was not holding it without the handbrake…..the only option was to drop the engine and start again……. At the end of October it headed off…………
1st Dec 2024 10:16pm |
So plan was for them to remove and replace engine assembly and carryout full inspection and gasket and seals check on engine and renew any missing or leaking parts……basically re-install engine to spec….and flag any major defects to be sorted……
1st Dec 2024 11:03pm |
Glad to hear it's back and you can get on with the other bits and pieces now.
1st Dec 2024 11:22pm |
Dh25 Member Since: 01 Dec 2024 Location: Moray Posts: 4 |
Great project! Will be watching your journey. All the best! |
2nd Dec 2024 10:53am |
The issue appears to be an intermittent fault code causing the car to enter restrictive performance mode. Using a GAP tool, I identified the code as P0018-00 (AE) - Camshaft Position - Camshaft Position Correlation Bank 2 Sensor 1, which often points to a timing chain issue. The engine was running very rough, further suggesting this. However, after speaking with the original garage that sold the car, I learned the timing chains, covers, tensioners, and guides were all replaced at 113,000 miles in 2019, shortly before they sold it.
3rd Dec 2024 1:44pm |
Initial inspection video..... lots done I forgot to mention above....... https://www.youtube.com/shorts/APTgzMyzVkI |
3rd Dec 2024 1:57pm |
While tackling the previously mentioned electrical work, I also spent time preparing the car for its MOT. One major task was addressing the glass, starting with the front windscreen. I ordered a brand-new windscreen directly from Land Rover (LR039064), which is the standard glass with a rain sensor mount.
3rd Dec 2024 2:14pm |
After spending countless hours polishing the side glass—and even consulting a professional glass polisher for a quote—I had to weigh the value of my time against simply biting the bullet and replacing the glass. I know it sounds a bit crazy, especially given the cost, but it was the only practical solution in the end. With the old glass removed, I now have the option to either continue polishing it when I have spare time or sell it on eBay as a project for someone else to clean up. I took advantage of the Black Friday sales and bought all Land Rover Genuine Glass directly from Land Rover, including LR017465, LR017466, LR017463, LR039062, LR039060, LR040920, and LR040918. All the glass matches perfectly, featuring a rear dark tint, laminated construction, and climate glass. As this is a car I will never sell.......it is a worthwhile investment....... |
3rd Dec 2024 2:30pm |
When I first got the car, I knew the interior was going to need a lot of work to get it looking even remotely acceptable. Honestly, why anyone thinks it’s a good idea to put engine parts on leather seats is beyond me!
3rd Dec 2024 2:57pm |
Although I’m still dealing with the intermittent P0345-02 and P0390-02 fault codes that occasionally throw the car into restrictive mode, they held off just long enough for it to pass its MOT.
3rd Dec 2024 3:03pm |
That's a massive amount of work you've put into that car! A fantastic result with the MOT too! Well deserved after all of that effort!
3rd Dec 2024 10:17pm |
