Home > My Range Rover > Another rescued L322 - 2011 5.0 SC Autobiography……Copart |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 185 |
Looking forward to further updates on what needs to be done. |
14th Oct 2024 9:39am |
Salter121 Member Since: 20 Jun 2018 Location: Berkshire Posts: 128 |
Once I got the car delivered, it was time to investigate. Clearly, people don't sell a car like this at auction to make a profit. I knew it was likely because someone either did not have the knowledge or the budget to sort it out—my biggest concern was the engine.
16th Oct 2024 8:19am |
As you can see - missing a shroud...the gearbox oil cooler also attaches to this shroud so that was just there loose.....
16th Oct 2024 8:26am |
Power steering reservoir loose, missing the bracket and totally facing the wrong way?
16th Oct 2024 8:29am |
Left and right Oxygen sensor heat shields in the boot.....
16th Oct 2024 8:38am |
Had no idea what this was - after spending ages going through TOPIX, I found it - goes on the rear right side of the engine
16th Oct 2024 8:43am |
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 394 |
Appreciate the detailed update, quite the project.
16th Oct 2024 8:57am |
Top mounting bracket front he ECU was in the boot.....initially had no idea what it was..
Had to replace a bunch of parts at the rear of the engine bay to re-house the ECU's and replace a uber of the rubber seals.... the scuttle panel willed replacing, the rubber seal is perished and it has been letting in water for a while....previous repair attempts with Tiger Seal look awful...
16th Oct 2024 9:14am |
Painstakingly, I began working through the front of the car, undoing everything that had been installed incorrectly. I used cable ties to ensure everything was secured properly, with no cables touching anything hot. I installed a new shroud, refitted the gearbox oil cooler, and addressed various other issues.
16th Oct 2024 10:28am |
Having got the engine back together correctly to the best of my ability - it was time to get it booked into Nick Kerner 4x4 to get the gearbox looked at and get their eye on it for an expert’s opinion on what else was needing doing - while waiting for this it was time to get a few of the exterior jobs done!!! |
17th Oct 2024 5:55am |
First wash in a very long time ! Those wheels have to go……
17th Oct 2024 6:01am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3242 |
Impressive work.
17th Oct 2024 6:47am |
I did actually think the same, that it might have had a new engine; however, the numbers match. I initially thought that with the power steering reservoir being in the wrong place that it was an AJ engine from a Jag as it was kind of position in the same place as they have it slightly up higher in the engine bay
17th Oct 2024 8:53am |
