Home > Maintenance & Mods (L322) > Foundry finish interior
Page 3 of 4 <1234>
algt2
Scotland 2006 Range Rover Vogue 4.4 V8 Zermatt Silver
I think that the paint you use has to have a plasticiser if you’re doing large areas, it bonds and keeps the paint flexible, I think Thumbs Up
Post #66370 30th May 2011 5:53pm
piersie
England 2003 Range Rover Vogue Td6 Epsom Green
As i speak,my entire cup holder is now covered in a plastic primer,(looks better already) , tomorrow i shall rub it down and re coat, then i wll respray the whole thing in a metalic paint i bought in Halfords which looks a real match. Time will tell how good a match. i would post pics but havent got a clue how to. Thumbs Up
Post #66453 31st May 2011 1:26pm
Vogue
DO NOT USE THIS TAMIYA PAINT it bubbles up the remaining finish where the two paint types make contact, it might have worked on a cup holder but it certainly doesn't work to touch up the rear centre consol.
It reacts and makes a simple touch up job 10 x worse and looks a bloody mess. The two paint types are not compatible.
Post #67142 5th Jun 2011 9:38pm
algt2
Sorry for any disasters guys! it just worked for the chips in my photos and thought I’d pass it on, hope it hasn’t caused too much heartache ! Embarassed
Post #67146 5th Jun 2011 9:50pm
Vogue
no worries, not your fault, I should have tried it on an inconspicuous spot first Thumbs Up
on another subject a company was selling a walnut trim to cover this section of the rear consol as a quick fix. I can't find it anywhere - checked the usual sources powerful and pimp my range etc but no luck, think it might have been a company in the US of A.... anybody got any ideas?
Post #67147 5th Jun 2011 9:55pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
has anyone found a replacement paint to fix chips, read somewhere are about some halfords paint but not seen any pics of it
Matt
Post #67158 5th Jun 2011 10:19pm
Vogue
this might be of use for others :-
http://www.rangerovers.net/forum/viewtopic.php?f=2&t=37789
Post #67161 5th Jun 2011 10:31pm
piersie
Thank god its not me being a pratt.
My cup holder reacted so badly,and yes it bubbled up and peeled off,even inside the holder where i hadnt touched. It blistered.
My fix was totally strip it with smooth fine glass paper. Clean it and dry it. Using a plastic primer (Halfords) gave it a couple of generous coats 2 hrs between each coat.
Finally i sprayed it with a Ford aerosol metallic grey the actual colour is out in the garage,and although im keen its tipping it down outside so i will get the name of it tomorrow.
The result is brilliant,in fact i would go so far as to say i intend to do the lot,when i have time,as its going to be far more durable then RRs atempt.
Hope this helps. Thumbs Up
Post #67170 5th Jun 2011 11:42pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
lucky i'm a lazy git and never even took my out the packet....thanks for heads up.
and to OP, not your fault mate didnt happen to you and you was only trying to help\advise. 2004 black Vogue TD6
Post #67284 6th Jun 2011 7:03pm
AndrewT
New Zealand 2003 Range Rover Vogue 4.4 V8 Oslo Blue
Has it stopped raining long enough for you to get out to the garage and check the paint colour yet?
I've tried a couple of Ford colours and can't get a decent match.
Post #70185 27th Jun 2011 7:13pm
Is the foundry colour the same as the outside vents and bonnet vent? If it is Rover steel grey is a good match. Joe90 is to thank for that one! Thumbs Up I sprayed my bonnet vent last week with it.
Post #70207 27th Jun 2011 8:41pm
AndrewT
I don't think so. The outside bits are Brunel grey and aren't as metallicy.
Post #70225 27th Jun 2011 9:30pm
Ah ok. Do use rover grey then. Lol. Thumbs Up
Post #70236 27th Jun 2011 10:32pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Found 2 sites in USA. They seem to have a much bigger range than anyone over here.
Www.wooddash.com and www.burlwooddash.com
They do plastic and real wood trim kits. The prices seem quite good for the size of the kits. The only problem is that certain parts are different for left hand drive (door switches etc.)
Hope this is of use. No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #70404 28th Jun 2011 8:48pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
I have carried out a test on a piece of console trim as I wanted the textured finish but in a darker colour than the foundry. Similar to the new ones. Here are some pics of the test stuff. Ignore the quality of the paint job as it was a rush job and I need to respray it to look better, but after drying it has evened out over the plastic and is a little more textured than the genuine foundry finish but it might look more rugged in theme for an off road car.
It is Rustoleum textured in Aged Iron, will see if it reacts over time as it is meant for metal.
Foundry piece on the top, my painted piece on the bottom.
 Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #181474 5th Apr 2013 6:23pm
Page 3 of 4 <1234>
