Home > Maintenance & Mods (L322) > Foundry finish interior |
piersie Member Since: 18 Dec 2010 Location: Berks Posts: 97 |
As i speak,my entire cup holder is now covered in a plastic primer,(looks better already) , tomorrow i shall rub it down and re coat, then i wll respray the whole thing in a metalic paint i bought in Halfords which looks a real match. Time will tell how good a match. i would post pics but havent got a clue how to. |
31st May 2011 12:26pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3747 |
DO NOT USE THIS TAMIYA PAINT it bubbles up the remaining finish where the two paint types make contact, it might have worked on a cup holder but it certainly doesn't work to touch up the rear centre consol.
5th Jun 2011 8:38pm |
algt2 Member Since: 01 Jan 2011 Location: Edinburgh Posts: 65 |
Sorry for any disasters guys! it just worked for the chips in my photos and thought I’d pass it on, hope it hasn’t caused too much heartache ! |
5th Jun 2011 8:50pm |
no worries, not your fault, I should have tried it on an inconspicuous spot first
5th Jun 2011 8:55pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
has anyone found a replacement paint to fix chips, read somewhere are about some halfords paint but not seen any pics of it
5th Jun 2011 9:19pm |
this might be of use for others :-
5th Jun 2011 9:31pm |
Thank god its not me being a pratt.
5th Jun 2011 10:42pm |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 |
lucky i'm a lazy git and never even took my out the packet....thanks for heads up.
6th Jun 2011 6:03pm |
AndrewT Member Since: 20 May 2011 Location: Auckland Posts: 97 |
Has it stopped raining long enough for you to get out to the garage and check the paint colour yet? I've tried a couple of Ford colours and can't get a decent match. |
27th Jun 2011 6:13pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Is the foundry colour the same as the outside vents and bonnet vent? If it is Rover steel grey is a good match. Joe90 is to thank for that one! I sprayed my bonnet vent last week with it. |
27th Jun 2011 7:41pm |
I don't think so. The outside bits are Brunel grey and aren't as metallicy. |
27th Jun 2011 8:30pm |
Ah ok. Do use rover grey then. Lol. |
27th Jun 2011 9:32pm |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 |
Found 2 sites in USA. They seem to have a much bigger range than anyone over here. Www.wooddash.com and www.burlwooddash.com They do plastic and real wood trim kits. The prices seem quite good for the size of the kits. The only problem is that certain parts are different for left hand drive (door switches etc.) Hope this is of use. No longer FF owner but still interested. Present car Jaguar XE ............................................ Previous car Td6 SE ................................ Previous LR- Disco 300TDi Auto |
28th Jun 2011 7:48pm |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
I have carried out a test on a piece of console trim as I wanted the textured finish but in a darker colour than the foundry. Similar to the new ones. Here are some pics of the test stuff. Ignore the quality of the paint job as it was a rush job and I need to respray it to look better, but after drying it has evened out over the plastic and is a little more textured than the genuine foundry finish but it might look more rugged in theme for an off road car.
5th Apr 2013 5:23pm |
