Home > Technical (L322) > Cranks but doesn’t start P1180 p1602 p2541 |
ThomasKubota Member Since: 22 Oct 2019 Location: Panama Posts: 6 |
Hi, everyone. Could someone help me?? I’m having a big problem with my range rover l322 3.0 diesel td6 the car cranks but doesn’t start . Code : p1180, p1602, p2541. I already replaced the tank pump, rail sensor. |
6th Oct 2024 5:38am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
When my TD6 did that, I had to replace the fuel pump under the sill below the rear passenger door…. Nearside UK. No warning, just didn’t start. To make sure you can pull the inlet pipe off the fuel filter under the bonnet and see if it’s getting fuel when cranking.
6th Oct 2024 9:35am |
