Home > Technical (L322) > Cranks but doesn’t start P1180 p1602 p2541
ThomasKubota
Panama 2006 Range Rover HSE Td6 Adriatic Blue
Hi, everyone. Could someone help me?? I’m having a big problem with my range rover l322 3.0 diesel td6 the car cranks but doesn’t start . Code : p1180, p1602, p2541. I already replaced the tank pump, rail sensor.
Post #701590 6th Oct 2024 6:38am
mjdronfield
When my TD6 did that, I had to replace the fuel pump under the sill below the rear passenger door…. Nearside UK. No warning, just didn’t start. To make sure you can pull the inlet pipe off the fuel filter under the bonnet and see if it’s getting fuel when cranking.
Don’t know what your codes are though, so I could be something completely different.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #701611 6th Oct 2024 10:35am
