Home > Technical (L322) > 4.4 tdV8 Starter motor investigation. |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
Low voltage and low current is due to inadequate gauge wiring and will cause the contacts to not be closed with the force required to prevent excessive burning which eventually leads to carbon build-up on the contacts resulting in no power to the starter motor. |
27th Sep 2024 8:57pm |
Shovie Member Since: 04 May 2021 Location: Wickwar area Posts: 14 |
You are correct James., I added the wire & it did not resolve the problem so I removed, stripped & cleaned the starter motor solenoid contacts that were badly pitted & its been no problem every since. |
30th Sep 2024 7:27pm |
The bypass wire cannot fix burnt contacts, it is purely preventative. |
30th Sep 2024 8:33pm |
