Home > Technical (L322) > If I disconnect the battery............... |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3724 |
In the past with other makes if I disconnect the battery i need at the very least to enter a Radio code. maybe reset of few other things and the clock.
27th Jun 2011 12:32pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3720 |
I disconnected mine to replace the battery - absolutely no issues or codes required on start up. |
27th Jun 2011 12:42pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
might be worth turning the steering wheel full lock left and then full lock right to reset the steering parameters.. |
27th Jun 2011 12:47pm |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
I had the same issue with my steering wheel , as I put the key in the ignition, it just started to drop down and would go all the way (i.e. virtually onto the seat) unless i moved the steering wheel adjuster in any direction, which immediately stopped it. Mine ended up in the dealers who initially thought it needed recalibrating (think the seats and steering wheel have their own 'ecu'), but in the end ,they changed a sensor I think. Luckily , mine was under warranty, unfortunately, that means I have no paperwork to see what part was changed. Steve
27th Jun 2011 6:30pm |
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 |
Ah...the mystrey of the steering wheel which tries to slice off yer nuts! Happened to me twice now over the last 6 months. Does anyone know why this happens?? Current MY2020
27th Jun 2011 6:53pm |
