Home > My Range Rover > 5 RRs and I have to give up |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3722 |
Really ? It’s 18 years old - what did you expect 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
28th Sep 2024 9:45am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8091 |
I know a good therapist.... Having driven your 405, which seemed perfect to me, I have to say I think a lot of your disappointment maybe because you don't really want one...
28th Sep 2024 12:18pm |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1336 |
Step into a 5.0 and the smile will return |
28th Sep 2024 1:26pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7727 |
Mines gonna cost me about £2600 next week, it can’t be worth any more than 10k. I’ve only done 1500 miles this year. Questioning my sanity too…. 🤣
28th Sep 2024 5:59pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2626 |
Yup get a 5 litre , expecting a revelatory experience in an old full fat might be too tall an order |
28th Sep 2024 6:24pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3099 |
New shocks on each corner will fix the bouncy ride and an EGR delete may fix the laggy engine response. 2012 TDV8 Vogue (L322) |
29th Sep 2024 11:18am |
He tried new shocks all round along with lots of other bits and reckoned it was just the same, and that was across three fatties IIRC.... Pete
29th Sep 2024 12:48pm |
New shocks definatley improved mine after 170k miles on the old ones. Maybe slightly harder ride ( vastly improved with new tyres) but way better body control during changes of direction. I guess it depends how worn the original shocks were. Mine were still fully functional just not optimal. 2012 TDV8 Vogue (L322) |
29th Sep 2024 12:54pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2425 |
I wear-out shocks in 80K Kms where I drive, although I put up with the worn CVDs by recalibrating until around 130K Kms because of their high replacement cost. |
29th Sep 2024 1:10pm |
Never found the calibration feature in the GAP IID tool to do anything noticable. 2012 TDV8 Vogue (L322) |
29th Sep 2024 1:12pm |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 628 |
I openly admit that everything points to me being the problem and not the cars.
30th Sep 2024 8:08pm |
For the heavy steering, you could try unplugging the electrical connector on the servotronic valve on the neck of the rack to check that the steering is then heavier at slow speed, as evidence that the valve is working. You could also check that the gauze in the bottom of the reservoir isn't mostly blocked, or simply whilst idling that there is significant disturbance in the reservoir indicating good surplus capacity from the pump. |
30th Sep 2024 9:43pm |
Hi Graeme,
30th Sep 2024 10:30pm |
JackRegan Member Since: 20 Oct 2012 Location: Wirral Posts: 204 |
When we look back, it's often in fondness.
1st Oct 2024 7:20am |
